Results 1 to 6 of 6
Thread: i need fluids!
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Default i need fluids!
    i took my v6 out today, so i'm on the home straight to the v8 conversion. tomorrow i'm going to hit up ricerbarn/repco/whatever for the various fluids i'll need.
    what brands do you guys recommend for fluids for a stock VS 304, 5 speed and alloy/aluminium radiator
    i want to get a good oil and coolant, and also think it'd be good to change the t5 oil while it's out. i lost a bit of oil when i took the tailshaft off the diff pinion flange, i guess that means a top up of the diff oil.
    i'm not hell cashed up at the moment so no royal purple oil
    also the diff's coming out in a month or so for an lsd and gears to go in, i don't want to fill that with top shelf oil
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Repco has some fluids on special for fathers day. Castrol LSX90 diff oil is one of them as is Penrite
    Vp series 2
    Jun 2008
    how long has the v8 been sitting?
    do you know it's history?
    if a long time or not sure then use a cheaper high detergent oil to flush the engine before using penrite.
    get a box oil that is limslip ok so you can use it for the diff aswell.
    you will need a addative for the diff to.
    many brands off coolant so just pic one.
    I can't remember which one but there was a coolant that had a 1000 000km life
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Quote Originally Posted by centy View Post
    cool, some good info on the box/diff oil. engine came out of a a SS ute, not sure of the K's on it, think it sat for a month or so, it's got no oil in it now tho.
    forgot to mention that until i get the gregories for a v8 i'm clueless about volumes needed to fill stuff like oils, coolant etc.
    car
    Jul 2006
    greensy, melb
    ive tried quite a few different oils for the engine and the one that i liked the best was penzoil gt perfomance, just make sure it is a 20/50 weight.
    also with the gearbox its a bit of a mixed decision, you can go gearbox oil or auto fluid with lubrizol, i use the auto fluid with lubrizol and the box feels great and im pretty sure it was from vr onwards it was recommended in the books to use auto fluid with additive in the manual box's.
    "A life lived in fear is a life half lived"
    vnss
    Jan 2005
    s.e melb
    go to r&e autos, ricabarn and supercrap are too expensive
  1. Hearing Very Loud Running Of Fluids After I Turn The Car Off..Help?
    By social in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-11-2008, 07:54 AM
  2. changing fluids
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-05-2006, 11:21 PM
