Results 1 to 7 of 7
Thread: any reason this would be a bad idea?
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Default any reason this would be a bad idea?
    i wanna relocate the charcoal canister while my bay is empty, and i thought that since i was doing it, i should get rid of the metal line that runs along the rail in the bay.
    my thought was to hacksaw it off just after it came out at the firewall, then use fuel hose (like it uses at the end where it joins) to run under the chassis rail to the charcoal canister's new location.
    as long as i hose clamp it on at both ends, use proper fuel hose, and make sure it's held tight to the underside of the rail, is there any reason this would be a bad idea or illegal or anything?
    VN_chris is offline Banned
    VN Commodore S
    Jul 2009
    Wollongong
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    it absorbs fuel vapour from the fuel tank and the lines run to the TB where the vapour mixes with the air and gets burnt.
    they're counted as a pollution device, like Cats and whatever else. illegal to remove
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    think of it this way - by the time you have your bonnet up and are explaining where your charcoal canister is, the canary is already written - whether the modification is legal or not.
    as far as EPA clearing it - I think it'd be a case of "if it works like it did before, it's fine"
    Jun 2005
    ive seen them mounted in the rear wheel arch. try explain that one to a cop haha. legal but would look a bit strange. i eventually need to mount mine properly below the battery since my thermo fans get in the way of it
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    am i likely to catch fire and explode hacksawing slowly through the line, given it's hooked up to the tank
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    Maybe make sure you drain it first.... and maybe even disconnect both ends and fill it with water, before you saw.
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
  1. VN diff in VK - it should fit - any reason why not?
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-06-2010, 12:04 AM
  2. Good Idea? Bad Idea?
    By WogBoyz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2009, 01:00 PM
  3. Horn goes off for no reason?
    By Jbird in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-12-2008, 11:58 PM
  4. I need a reason
    By BlackVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-09-2008, 03:46 PM
  5. Car Alarm goes off for no reason
    By Harry V in forum Electrical Wiring / Questions
    Last Post: 06-07-2005, 10:03 AM
