Results 1 to 8 of 8
Thread: [SA] VP V6 Commodore Executive - Surging issue.
    VQ Caprice II
    Aug 2006
    Default [SA] VP V6 Commodore Executive - Surging issue.
    Hi everyone, this will be my first post for engine mechanical issues.
    Engine : V6
    KM's Travelled : approx 180,000km
    Problem: Surging at idle - sounding like one piston faulty.
    Items Changed/ Checked.
    Changed :
    All 6 Injectors
    Oxygen Sensor
    Coil Pack
    Checked:
    Ignition Leads - with multimeter all ok.
    Fuel Pressure regulator - Vaccum hose removed, no fuel shown in pipe.
    ECU (COMPUTER) - swapped with a perfect running VP Calais no difference to surging problem.
    Fuel Pump - Checked
    Map Sensor - Checked
    Vaccuum Lines all checked and are connected.
    Exhaust emmisions - inside the exhaust it is showing perfect combustion, eg. no carbonisation, and is running efficient.
    Items not checked - YET
    Throttle body position sensor
    Idle Bypass Vacuum Modle.
    [B]ProblemB]
    When the engine is idling the revs go up and down kinda like a injector or spark plug being faulty, but when you check at the exhaust pipe there is no missing at all and is "whistling" like a new engine.
    Findings:
    Injectors - When I disconnect each wire on each of them - A visual decrease in revs is shown.
    Injectors - I can change the wire connection for 1 & 3 and 4 & 6 eg. put 1 on 3 and 3 on 1 and same for the other two, but I have found that it makes no difference - Question ? How do you tell which order is correct as the connectors have random numbers nothing showing eg. 1 for 1. etc.
    Main Vaccuum from inlet manifold to brake booster when disconnected engine revs increase dramaticly, (which is normal) but when I place my finger over the vacumm outlet on the manifold the engine almost dies completely - why?
    Solution?
    Guys/Gals any suggestions on where to try next? I wish to sell this car in the next week or so but when it is idling like this can makes the sale hard. I am willing to buy a carton of beers to the person who finds the solution . (Shrugs shoulders - HELP).
    Thanks
    Spirto.
    VQ Caprice II
    Aug 2006
    brockee's Avatar
    brockee is offline (HOUSE OF POWER)
    VX S2 SENATOR SIG CAMMD A4
    Aug 2009
    mandurah> wa
    are the injectors seated properly no o rings fallen off or in the holes check!!!! also could be throttle pos sensor
    VQ Caprice II
    Aug 2006
    Hi there,
    All injectors are seated correctly and have all the o'rings. I am checking the throttle position sensor this week as well as the Idle Vacuum Module.
    Will let everyone know my findings when I know... but this is making me tear my hair out LOL.
    Spirto
    brockee's Avatar
    Aug 2009
    mandurah> wa
    VX 2001
    Feb 2011
    VP executive sedan V6
    Feb 2011
    nowra, NSW
    I was going to throw in is the AC on? If it's borderline for pressure it will cut in and out and cause a pulse or surge when idling and under load. If it's fixed what was it?
    cheers
    VQ Caprice II
    Aug 2006
    Hi guys, sorry hadn't subscribed to my thread, didn't find the solution, thanks for the suggestions. I ended up increasing the revs, replaced the oxy sensor,.even the computer with no luck, car was for sale, ended up being sold as it was. Close thread.
  1. VX Commodore Issue
    By WinterVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-01-2010, 03:21 PM
  2. VX Commodore deadlock issue
    By rickburt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2009, 09:54 PM
  3. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  4. VT Commodore Starting issue
    By hitman1979 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-02-2008, 10:00 AM
  5. 95 VS Commodore Executive Issue
    By commodoreant75 in forum Electrical Wiring / Questions
    Last Post: 05-10-2007, 03:10 AM
