Results 1 to 7 of 7
Thread: Few q's
    skunks.monks's Avatar
    skunks.monks is offline The one that you missed
    Toyota Lexcen (VP)
    Jul 2008
    Default Few q's
    I was wondering if a VS altinator will fit onto a series II VP Buick motor??
    also are VS II front seats easy to put into a vp?
    and is it hard to take the vp seats out??
    Check out my VP
    Wanted to Buy VP Front & Rear Bar/Bumpers
    skruba is offline holden, honda, pitbulls
    vp executive
    Jun 2009
    parkes nsw
    seats will go straight in 4 allenkey bolts to the floor alternator i am not 100% but think it wuld work
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Alternator should fit, seats will fit straight in. Easy to take the VP seats out, as said above, 4 bolts on each front seat, rear bench seat is slotted onto rails, just slide them off the rails (that applys to the base and backrest).
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    Toyota Lexcen (VP)
    Jul 2008
    yeah i knew the rears would be fine, it was the fronts that was worrying me.
    and thanks for the info
    Will let u all know how i go 2morrow
    Also forgot to ask... my passengers side door doesn't unlock with the key, but central locking works with the drivers side, so the passenger door unlocks, but cant use the key...
    the key doesn't actually turn, and won't turn, its like jammed into that spot...
    anyway i can fix this without having to replace the lock?
    Check out my VP
    NO CAR ATM.. -.-
    Jul 2006
    Vp series 2
    Jun 2008
    Toyota Lexcen (VP)
    Jul 2008
    is it bad to have a coolant smell when your car has been running a while and u turn it off?
    like it smells like its running rich on coolant...
    Check out my VP
