Results 1 to 3 of 3
Thread: audio problems
    vp calais
    Aug 2009
    Default audio problems
    hi im shaun.
    i recently brought a new kenwood car stereo and im having some probles installing the unit.
    i took out the old eurovox cassete unit and i then clipped the wiring not realising that i should have broght a wiring harness. than i tried wiring the old ones to the new and because it had different colour coding i had no idea wat the **** i was doing. so i went and brought a wiring harness and re-crimped on the old harness then wen i finally done it all and plugged in my new stereo with the new wiring harnesses it didnt work although it would still take a cd but no audio. basically the problem is tht there is no display on the face.... and the old one worked fine wen i had it in. but now even wen i chuck the old eurovox back in there is still no lights on tht either.......
    can any one plz help me
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    not sure bout your prob did you use this wiring thread-
    Stereo Install/Removal (VN - VS)
  3. Default
    something is wrong so piss off the old harness you re-crimped and the new harness as well. if it takes a cd that means you've got the constant right, but your acc is fluxed.
    now you've just got the wires, here's what they mean:
    Accesories - Yellow
    Constant - Orange/White
    Illumination - Brown/White
    Earth - Black/White
    12V OUTPUT - Yellow/Red
    Speakers
    Front Left (+) - Tan
    Front Left (-) - Grey
    Front Right (+) - Light/Green
    Front Right (-) - Dark/Green
    Rear Left (+) - Brown/Black
    Rear Left (-) - Yellow/Blue
    Rear Right (+) - Blue/Orange
    Rear Right (-) - Blue/Black
    refer to your headunit installation guide and wire it up. for testing purposes just twist and tape to see if it works. no point soldering if it's still wrong or not working. i actually leave mine like that as well, but that's 'cause i'm dodgy and i wouldn't recommend doing that.
    Quote Originally Posted by zai View Post
    I am not sutpid
  1. VT Calais audio problems!!
    By VTCalaisV8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2008, 08:42 PM
  2. Audio Problems
    By speedracer006 in forum Car Audio
    Last Post: 01-04-2007, 11:48 AM
  3. not quite audio but is used for audio purposes...
    By Tasmaniak in forum Car Audio
    Last Post: 11-08-2005, 02:50 PM
  4. Car Audio Problems
    By nick_27 in forum Car Audio
    Last Post: 30-07-2005, 05:37 AM
  5. Car Audio Problems?
    By 1tuffvn in forum Car Audio
    Last Post: 04-07-2005, 07:00 PM
