Results 1 to 6 of 6
Thread: Rear Ciggie Install
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    Default Rear Ciggie Install
    Um where does the blue wire connect to on the other side front end of the console?
    I think I've got everything else right but I don't know what this blue wire connects to because theres no blue wire on the other side of the loom for the front lighter at near the gear shift.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Are you running a complete transplant console from a calais/statesman? Does it have the light inside the console? I seem to have this vague memory of the blue wire running to the tilt switch so the light comes on when you open the console lid... I could be making that shit up though.
    The 1972 HQ Kingswood
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    uhh, from memory (S1 VN Calais), there's a brown, yellow and blue wire.
    One is positive power for aux power, one is earth, and the other is positive for the light on the socket.
    Just grab a test light, and check which is which.
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    I've got all the other wires done up, its got an after market lighter in front so the colors are a bit different, on the stato loom i have black on black yellow and brown onto themselves ect. I just spliced in, but I cant find any blue wires there, on the other end it just connects straight to an earth, so I think you may be right morton, but for me its not important cause I don't have it(might do it later on). It also doesn't go all the way through the loom so I think this supports your theory also. Thanks for all your help guys.
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Morton is right. Blue wire is for the light in the centre console. Should end in a black right hand connector. Also is quite short and won't reach the other ciggie lighter.
  1. Rear 1/4 Glass Install - Help
    By Verillius in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2011, 03:28 PM
  2. Ciggie Lighter Issue
    By Badger in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2009, 12:18 AM
  3. ciggie lighter woes
    By POZ-468 in forum Electrical Wiring / Questions
    Last Post: 07-04-2006, 08:21 PM
  4. Rear suspension FE2 install HOW-TO
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-12-2005, 10:51 PM
  5. Ciggie Lighter
    By drewzle in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2004, 11:36 AM
