Results 1 to 3 of 3
Thread: wat is my gearbox
    91 VN S2
    Jul 2009
    townsville
    Default wat is my gearbox
    hey guys, i got a S2 vn and had a leak in the gear box when put on the hoist to have a closer look it apeared that the transmission lines had been cut and replaced with rubber hoses (one of them split) to fit around the bell housing, now as far as i know the lines on the t7's should be 8mm pipe all the way through so wtf, theres no mod plate in the engine bay put found a users manaul for a company call B,B,E automatics in the glovebox, any help will do
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    what is the question, if the pipes are 8mm or if they should be all steel, a lot of dodgy's use rubber hose if they accidentally crimp the cooler lines when r&r'ing the box, as you probably know, they don't bend back without breaking once bent too far. There is a BBE auto joint here in Vic if that helps.
    91 VN S2
    Jul 2009
    townsville
    Quote Originally Posted by shiftySLE View Post
    ya they are supposet to be all steal but the mechaninc that recently replaced the hose(because like most people i dont have the luxury of a hoist) he said it wasnt a T7 box so ya and theres no mod plate so ya cheers for the bbe info to ill give them a call..............
  1. Bye bye gearbox
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2009, 01:21 AM
  2. Gearbox
    By lachie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2009, 07:50 PM
  3. Hos On Top Off Gearbox
    By mick1979 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2009, 01:24 PM
  4. VS 5L gearbox into VR 5L??
    By mess666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2006, 06:00 PM
  5. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
