Results 1 to 9 of 9
Thread: adding Intirior lights (maplights)to a vn, easy or hard?
    VN S
    Aug 2009
    Default adding Intirior lights (maplights)to a vn, easy or hard?
    as stated, is it easy or hard to wire up map lights in a vn? as they dont have them in the front, id want to be able to turn on with the button on them like usual but they dont have any wiring for that so would it just be easier to wire them to the same light as the existing interior light so i just hit the dash button an they all come on? an to do that would it be safe to just run new wires from the center light to the front and mount a light there or would that be stupid and unsafe?
    thanks,
    Kodie
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    The calais interior light with map lights bolt straight in. They wire up same as your old one would. And the map lights work when you turn them on.
    VN S
    Aug 2009
    is that the center light with map lights? or one that goes at the front near the rear view mirror, cause i just have the single interior light in the center that comes on with the doors, and has a switch on the dash.
    TVR-190's Avatar
    TVR-190 is online now SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    thats the interior one in the middle has the usual accent light that comes on when you open the doors, dash switch also control it. plus two map lights at the front that are controlled by their own switch.
    The Black Beauty
    VQ Caprice II
    Aug 2006
    The easiest option I aggree is the Calais center light which has map lights, here in Adelaide retails about $10 to $40 depending on which wrecker you get it from.
    Easiest way to wire it up, is remove yours via the screws, then cut the wires one has power "orange" I think the other one is "black" ground ....then just connect them to the calais light.
    When your cutting them perhaps disconnect the fuse first for interior lights, saving you any un-necessary sparks etc.
    cheers.
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    Yes the calais interior dome light with map lights bolts straight in. Unscrew your old dome light cut the wires. There will be 2 orange wire, one with a white strip on it. Simply hook it up how the old one was and the map lights work
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    Here's a lowdown on how the map lights magically work.
    There's a constant 12v feed going through one of the wires (can't remember which one). When the calais dome lights screw in, one of the screws acts as a ground that screws to the roof. Then the ground is connected to the switch so when you flick it, it grounds and HEY PRESTO you have map lights.
    I popped the 2 little plastic circles out to get better light coverage.
    VN S
    Aug 2009
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    Cheers Verynice
    (bit of a dig haha)
    Check It Out
    My 93' VR Executive
  1. Installing hard top, hard lid or hard cover?
    By clapnrobem in forum General
    Last Post: 12-10-2011, 08:36 PM
  2. Adding a Amp into VE SSV??
    By puganinni in forum Car Audio
    Last Post: 09-12-2008, 03:12 PM
  3. Wheel Bearings, easy or hard to renew
    By orchardm1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 09:02 PM
  4. Adding Fog lights to a STD VZ ute
    By CacTuar in forum Electrical Wiring / Questions
    Last Post: 01-08-2006, 07:48 PM
  5. Adding Driving Lights to VZ S Ute
    By Utester in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-05-2005, 04:52 PM
