Results 1 to 7 of 7
Thread: Aircon/Heater temp rod
    Smallies's Avatar
    Smallies is offline I hate carnies.
    VN Calais / 180SX
    Dec 2008
    Whyalla, SA.
    Default Aircon/Heater temp rod
    Hey,
    Was removing my head unit today in order to install a new one and inso doing I removed the aircon/heater controls. As i did, i removed the rod on the temp control.
    I'm assuming it goes to the white lever type part that makes the heater box make a noise if you move it lol.
    Just wondering if anyone can confirm my assumption or correct me.
    And what to do when re-installing
    I hope my description is adequate.
    Cheers.
    Please do not print this sweet post. Save our forests. Save our World.
    skunks.monks's Avatar
    skunks.monks is offline The one that you missed
    Toyota Lexcen (VP)
    Jul 2008
    Yes you are correct it goes to a leaver which opens and closes the heater box thing...
    if you have taken it out already, did u mark where the clip was on the rod b4 i took it off?? as it can be a pain in the ass to get back to the right spot!
    Check out my VP
    Wanted to Buy VP Front & Rear Bar/Bumpers
    Smallies's Avatar
    VN Calais / 180SX
    Dec 2008
    Whyalla, SA.
    eek. I just pulled it out......didnt mark anything.
    where do i go from here?
    Toyota Lexcen (VP)
    Jul 2008
    if i remember right to put it back in you move the control to hot (as far around as u can put it) and then try different spots on the road until u get the right spot for it to be able to turn it back all the way around to cold... or it could be the other way? i cant remember... sorry
    if someone else can confirm this? as i stuffed mine up and got a pro to do it when he replaced my heater core
    Check out my VP
    Vp series 2
    Jun 2008
    the clip has a little cover that loks down to hold the rod in place.
    lift that up first or buy a new one if it is broken
    move heater knob from hot to cold and watch the rod.
    move it to the outer most setting then push the lever on the heater all the way back. now install unit then clip rod into place. making sure it is still all the way out.
    In would work fine aswell.
    Jun 2005
    Quote Originally Posted by skunks.monks View Post
    not hard at all. turn the knob all the way to hot. move the white lever back as far as it can go. join together
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Smallies's Avatar
    VN Calais / 180SX
    Dec 2008
    Whyalla, SA.
    Cheers guys.
  1. VK heater / aircon.
    By streetholden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-05-2009, 05:11 PM
  2. VY heater , aircon controls
    By putz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-04-2009, 11:33 AM
  3. heater / aircon fan troubles (VS II)
    By oz-fr in forum Electrical Wiring / Questions
    Last Post: 27-05-2008, 08:48 PM
  4. Heater/AirCon Fan!
    By harvs01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2007, 05:25 PM
  5. VS heater aircon problem HELP!!!
    By Joecoxon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2005, 02:49 AM
