Results 1 to 7 of 7
Thread: radio antenna
    vp sedan
    May 2005
    Default radio antenna
    It seems the usual problem, supermarket car parks and manual antennas. Mine was broken yesterday so I was thinking of putting a power one in my VP.Exec. it is stock standard with the factory philips RC169 radio.
    Any special wiring required or will it be just a matter of putting it in and connecting things up, [ie wiring in place in a plug somewhere.] or is it a stupid idea and do supercheap or repco stock suitable antennas
    TVR-190's Avatar
    TVR-190 is online now SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    nah mate should be pretty easy to do, the ones from repco are generally pretty reliable
    The Black Beauty
    Vt-Brrrlina is online now vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    usually the power antennas come with a universal bracket.. easy enuff to make fit...
    they usually only come with 3 wires as well up .... down..... earth.
    i would probably personally buy a small switch or run to the factory buttons if u have them so u can decide up and down position as u drive, other wise hook the UP wire to stereo power and earth to earth. When u turn the stereo off the antenna will lose power and auto go down..
    vp sedan
    May 2005
    thank you guys, mine has no switch so i will attack the radio and wire it direct, just have to go shopping
    VQ Caprice II
    Aug 2006
    you can wire up an A/C switch as an over-ride, then when your playing your CD's etc, the antenna can remain down. It also helps when your going into low public car parks or parking under trees, switch in, no antenna, switch out antenna goes up. And you can wire it up from the antena power from the radio etc.
    Series 2 Manual Vn Wagon
    Jan 2009
    hawthorndene SA
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    They also most the time put the antena down when listening to CD's anyway.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
  1. VR S2 Radio Antenna Problem
    By marshcory in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2009, 06:07 PM
  2. VS Radio Antenna
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2009, 07:00 PM
  3. VT Radio Antenna
    By Hubba in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2006, 12:16 AM
  4. Disconnecting radio antenna/aerial
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 11:19 AM
  5. Vp Commodore Radio Power Antenna
    By Abe in forum Site Feedback / Site Problems
    Last Post: 02-02-2004, 03:43 PM
