Results 1 to 15 of 15
Thread: whistling noise?
    VS acclaim,
    Mar 2009
    Default whistling noise?
    just curious to know if anyone knows what this noise could be coming from and how to stop it, seams to be coming from dash speaker, but only happens when a window is down? its a mates vp and has done it since the day he bought it,
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Sounds like a Seal might be in the wrong spot (Or missing it)
    I know what you're talking about. But I've always thought its somthing to do with the Seals.
    Anyone, correct me if im wrong
    VS acclaim,
    Mar 2009
    which seals are you talking about? like window seals? all have recently been glued on securly, thought the noise was due to a dodgy speaker until i realised it was coming only when the window was down, i can get a video of the sound, gets quite annoying considering we smoke so windows are down most of the time.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    VS acclaim,
    Mar 2009
    Quote Originally Posted by Ozzie View Post
    Would be wind getting under a rubber seal somewhere.
    thought the same thing too, until i checked in in the garage, no wind at all, car on, windows down, still made the same noise.
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Is it comming out of the speaker itself?
    Is it under the bonet? might be the pcv hose
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    If it comes from the Speaker, I've had that issue before..
    I believe it was my AMP was not tuned right or something
    VS acclaim,
    Mar 2009
    well car was bought from a pretty dodgy wreckers, (****ed my mate round a bit, they put speakers in for him), sounds like its coming from the speaker, but if it was the speaker wouldnt the noise not come if the volumes on 0? dont think its coming from under the bonnet, seeing as it can only be heard in the car while windows are down?
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Check the pcv hose. (the vacumn hose at the back of the plenum) It might be split or not even connected.
    The firewall can stop alot of noise from the engine bay which you may only hear when the window is down.
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    VS acclaim,
    Mar 2009
    il check that out sometime today,
    VS acclaim,
    Mar 2009
    Quote Originally Posted by Wavez View Post
    What side? Maybe the side mirror?
    passenger side, il try get a video of the sound so it helps.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    VS acclaim,
    Mar 2009
    im 100% sure theres no crack in the passenger sides mirror's plastic and about 80% for the drivers side,
    i tried covering it with something today to check if it was the wind, still made the noise, will get video tommorow if that helps.
  15. #15
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    my vp dose this and mine is because the bonnet sits higher on one side than the other not sure about your issue good luck
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
  1. weird whistling noise when fitted 18's on my car ?
    By Vs_Esteem in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2008, 08:18 PM
  2. whistling vk
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2008, 07:50 PM
  3. VS acclaim whistling noise
    By holdi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2008, 08:18 PM
  4. whistling noise in the mornings
    By ilovemyvx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-07-2006, 01:20 PM
  5. My Vr Is Whistling
    By bizzo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2004, 11:13 PM
