Results 1 to 8 of 8
Thread: Is there a difference between the V8 and V6 auto gear boxes out put shafts?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Unhappy Is there a difference between the V8 and V6 auto gear boxes out put shafts?
    Is there a difference between the VP V8 and V6 auto gear boxes out put shafts and can you change them over because i want to convert my Pajero into a V8 and the only adapter for the transfer case is for a V6?
    Otherwise I'm going to have to look for a different solution.
    Thanks for any help.
    VP Executive R-spec
    Jan 2005
    Output shaft is the same, they are the same gearbox, only the front section and input is different
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    so realistically everything on the front of the box is different like the bell housing and what else ?
    see im interested now and im sure ya know why greeanfoam !!!!! lol
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    So if i get one of the Transfer case adapters from marks 4wd adapters-
    Mitsubishi Engine Info
    I'll be sweet!
    Thanks for the help
    VP Executive R-spec
    Jan 2005
    Might be a bit complicated with the sump and and mounts depending on how the Pajero is but you can get HQ style sumps for the 5 litre that are back to front if you have to
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by rob drag racer View Post
    Yeah the bellhousing and I think also the input shaft are different but you can get an adpater to run the V6 box behind a 304/8
    Jun 2008
    golden beach
    cool another handy tip for when i kill the v6 in the vn
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    yer i was thinking the same because the sump and pick up are at the wrong end, now all i need to do is figure out the engine mounts!!!!
  1. interchanging gear boxes.
    By SSbeast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-08-2009, 03:30 AM
  2. vn gear boxes
    By matty_vn_ll in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2009, 07:46 PM
  3. VS s1, s2 & s3 auto boxes. Are they all the same box? Any changes?
    By VSSECO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2008, 06:09 PM
  4. what's the difference between the v6 and v8 auto boxes?
    By vnstu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2006, 08:07 PM
  5. VT & VX auto transmission, any difference?
    By accentstencil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-07-2006, 01:39 PM
