Results 1 to 8 of 8
Thread: Headder Bolts VN V6
    VN Lukey's Avatar
    VN Lukey is offline BT1, the way to go
    Holden VN S1
    May 2009
    Unhappy Headder Bolts VN V6
    hye guys.. is it hard to double thread your exhaust headder bold ( going onto the block ) does it require alot of force to double thread it? and would the thread on the bolt double thread first before the thread inside the block double threads!
    thanks guys.. i need some quick answeres...thanks
    i really really worried
    VN Lukey's Avatar
    Holden VN S1
    May 2009
    Bump!
    sorry guys.. i know its sorta a stupid question but it would help if i had peoples opinions.. thanx
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Double thread? Cross thread maybe? Stripped thread? You would have to be a twit to cross thread them lol
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VN S1
    Jan 2008
    If you've cross threaded it once you remove it just run a tap through it and see if it can bring it back to life, if not just drill it out and go bigger bolts.
    vn calais
    Aug 2009
    northern burbs
    the bolt itself should go first seeing bolts are generaly soft but being on a head i would get a tap set and re-tap them ones you have done! this should not be to hard. or as said before drill them out and go bigger
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    If you going to re-tap your heads.... take them off first!
    This applies to re-drilling the holes too.... dont take any shortcuts.
    The easiest way to determine if you have done any damage would be to run a tap into the thread and try and guage the resistance you feel winding it in.. it should go in fairly easily.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Vp series 2
    Jun 2008
    when you get the tap ask for intermediate or bottoming tap.
    both would be best to get the thread clean all the way in.
    to go over size then spend the money and helicoil it back to original.
    VN Lukey's Avatar
    Holden VN S1
    May 2009
    thanks guys.. your a big help.. i fixed it today.. the left extractor off my VN V6 S1 was giving me trouble.. it turns out that the screw was being held down buy the steel coolant pipe and not going in properly and to top it off the gasket was slightly in the way stopping me from screwing it in.... :P .......LOL
    but i bet im not the first person to have that problem :P
    i was Shittn myself thinkin i had stripped the thread cause it was just screwing and screwing and screwing and not going anywhere..LOL
    thanks again guys... :P
  1. 304 ARP bolts
    By DANNY8 in forum V8 Development and Modification
    Last Post: 05-08-2009, 10:40 PM
  2. ARP bolts
    Last Post: 11-03-2009, 02:37 PM
  3. Flyweel Bolts S1 (6 bolts) How Do i Remove? Reverse or Normal?
    By social in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2009, 10:54 AM
  4. cat bolts
    By ear099 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2007, 03:14 PM
  5. help tow bar bolts
    By kegzcp308 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-12-2005, 08:56 PM
