cuckoo
- Feb 12, 2005
- 478
- 3
- 18
- Age
- 63
- Location
- Newcastle region
- VT V6 twin Turbo
Hi i will list the error codes for the VN v6 hope this helps
12 Sytem pass
13 Oxygen sensor (o2)
14 Coolant temp sensor - voltage to low
15 Coolant temp sensor - voltage to high
16 Coolant temp sender - voltage unstable
17 PCM coolant temp circuit
19 Throttle position sensor
21 Throttle position sensor - voltage to high
22 Throttle position sensor - voltage to low
23 Mass air temp sensor (MAT) - voltage to high
24 Vehicle speed sensor (VSS)
25 Mass air temp sensor (MAT) - Sensor or circuit - voltage to low
26 Mass air temp sensor (MAT) - Sensor or circuit - voltage unstable
28 Transmission problem
31 Theft deterrent system - missing signal
32 Manifold airflow (MAF) - sensor or circuit
33 Manifold absolute pressure (MAP) - voltage to high
34 Manifold absolute pressure (MAP) - voltage to low
35 Idle speed error
36 Vaccuum leak
41 Crank angle sensor
42 Electronic spark timming circuit (EST)
43 Knock sensor circuit
44 Oxygen sensor lean (o2)
45 Oxygen sensor rich (o2)
51 Memcal unit - check for bent pins
52 Calpak unit - check for bent pins
53 System over voltage - Alternator produced >17.1 volts for more than 2 seconds
55 ECM - Check ECM grounds or excessive inputvoltage
so there we have them hope this help
12 Sytem pass
35 Idle speed error
36 Vaccuum leak
