hey , i have a 93 5ltr VP commodore it has been sitting for over 12 months it was running when i parked it .Now i have put new battery in and try to start i get nothing no reds nothing any help would be appreciated ???????????????
Are the battery connections on properly? Is the fusible link OK?
yeah all connections on properly i can't see any problems with any wiring at all
Hmm.. Check all Fuses.. Oil , Starter Motor etc etc.
I'd be mainly looking at your Start Up Sequences tho. (Fuse/Ignition/Starter Motor etc)
Aslo, reset ya ECU.. If you get nothing, it sounds like your ECU may be dead or a lil wonky
check the main 100amp fuse
