what would be the best tool to take a towbar off, its a mates vp and we've tried wrenches and a few sockets, but nothing seams to even loosen it?
rattle gun hookd up to aircompressor or maybe tension wrench
cheers, will try soaking it tommorow, how much would a mech charge to take it off? surely not much?
stop being girls and use some fkn muscle ffs its only a towbar.
if you really cant get it off dont go to a mechanic go to a panel beater
crc and a sockets and a hammer to bash the wrench with.
Just get a long extension on the ratchet. I found 5 foot was about enough when I had issues. When that snaps the bolt, then use the angle grinder.
Hot Lap Motorsport
its not alays about how big you are and im not trying to sound tough either.
i have a mate who is nearly half my size but he an crack bolts i cant.
seems liek theyre rusted pretty tight and if thats the ase you will only break them using a lever.
wurth and matbe some other companies make a spray called rost off, its kinda like wd-40 but designed for rusty shit.
give that a go
grinder and cut the head or nut off the bolts.
or a nut splitter and split the nuts.
the nut splitter is harder to get hold of then a grinder.
if u can get a ratchet to grip bolt an then put a bar on it to xtend its length and u mite have better leveridge an honest u dony need to be a muscleman to do hardjobs im 18 5ft8 an weigh 65kg and iv surprised my BIG brothers wen it cums dwn to it
Big f**k off breaker bar and a steel pipe. Or a good rattle gun if you have a compressor..
yeah i had some issues with mine, i just put a spanner on there with a big ass pipe, worked a charm![]()
angle grinder thats how i got it off on the vp :P
