Results 1 to 14 of 14
Thread: Spluttering / dying when engine is under load
    n/a
    Sep 2009
    Default Spluttering / dying when engine is under load
    Hi fellas
    Made the mistake of buying a vn, so here I am.. 1990 S1 N series auto 200 xxx kms
    When im going uphill (the worst) or sometimes on the flat the car starts spluttering like its getting no fuel and eventually ends up dropping all revs to idle or sometimes cuts out completely and if i try to accelerate it make a kind of backfire noise... if i stop and leave it for 30 seconds and try to restart it's fine and continues to put along but a little worse etc etc .. happened 4 times on the way home from work yesterday (60ish/km)
    I thought maybe the fuel pump was on the way out so i put a full tank and took her for a drive later that night ... i got about 10km before it died on me again and that was on the flat.
    Tonight im going to replace the plugs and fuel filter, what else do you think i should look for?
    I've noticed a strong fuel smell from outside the car after it happens if that helps.
    It's an epic hassle atm so im trying to fix it asap. I think I've given you as much info as possible.
    Thanks to whoever helps
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Ahh. Im very positive its your Fuel Injectors.
    But, just to be sure,
    Check: Spark Plugs / Leads. Fuel Lines. Fuel Filter(s) Fuel Pump, these are your normal run arounds
    Just got a Q tho, Does your Car Backfire wile Driving at all?
    As for your Fuel Injectors, Try to throw some Fuel Injector cleaner in before you fill up, (Usually takes 2-3 times before it's noticeable)
    If that Fails, you most likely have a Clogged Fuel Injector.
    Sadly, it's to hard to say at the moment.. If you can give us more info etc etc Im sure we can help
    Good luck!
    n/a
    Sep 2009
    Nope doesn't backfire while driving .. untill it starts choking and dies then it'll backfire
    n/a
    Sep 2009
    Replaced spark plugs... helped it a little but then started doing it again after a day of driving
    Replaced the fuel filter the next day... seems to have fixed it, but i dont trust it yet
    Also, when looking around i found this but i have nfi where its supposed to be going...
    any help?
    Thanks
    Renno's Avatar
    Renno is offline Home Of The Shiny Tank
    VN Calais 5L
    Dec 2008
    Defected And In The Shed
    Quote Originally Posted by Mikel. View Post
    any help?
    Thanks
    That is one of the breather hoses for the fuel tank. If any of these perish (usually after the 20 years since these cars were produced they start to perish), you get the fuel smell comming in the cabin and around the rear of the vehicle.
    n/a
    Sep 2009
    the cars still giving me trouble with the engine spluttering and dying as i found out last night ... drove it around for an hour no worries then all of a sudden it done it...
    what's the chance that it's the cas? and how hard are they to replace.. i'll have a go this weekend if i can
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    mate is it only doing it like of a night when you run the lights? or in the day to without lights on...cause if it is then i'd say alternator is on way out as lights would take power away from your spark. just a thought
    VN Calais With All The Factory Fruit I Need!
    VN_chris is offline Banned
    VN Commodore S
    Jul 2009
    Wollongong
    any help?
    Thanks
    is your check engine light on? i have the same hose busted as in the pictures. were is it supposed to go?
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    99% sure that leads to the charcoal cannister, and is ment to be connected to the filler neck somewhere. do you smell fuel outside the car?
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VN Commodore S
    Jul 2009
    Wollongong
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    it either goes to half way up the filler neck (remove the metal plate in rear wheel well behind mud flap for access) or it will go to the top side of the fuel tank (undo the straps and lower the tank on a jack)
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The CAS will die when it gets hot and some times some cold water will get them going again.
    Running rough under load would probably be the coils or DFI unit under the coils. See if you can swap it with a mate.
    To replace the CAS the balance has to come off - no easy job if you dont have big spanners Also must be lined up correctly when going back in or the balancer will eat it in 1 second.
    and 3 Dangerous non ABS VN's
    vs v6
    Sep 2009
    i had very much the same trouble with my vs.. ex holden worker so i have very good knowledge how to fix em but this was a bitch.. that is your fuel line from the can to filler check the overflows on top of the tank (hard to see but lower one side of the tank u should be able to feel them) which cause fuel loss with out knowing.... what is causing your problem check your coil pack grab one from the wrecker (good to have a spare) should fix it
    n/a
    Sep 2009
    it wont happen if its cold... only once ive been driving for about 30 mins... but in saying that, it'll happen day or night, and sometimes i can get away with driving for an hour or two before it happens again
  1. VT-Engine miss's under load @ low revs
    By sportyclansman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-11-2008, 06:23 PM
  2. How to load engine on/off trailer?
    By Shounak in forum The Pub
    Last Post: 23-11-2007, 08:39 AM
  3. sputtering engine under load
    By blitzwurst in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-11-2007, 10:17 PM
  4. Engine struggles under load
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-03-2007, 08:18 AM
  5. spluttering under load
    By slappa. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2007, 06:24 PM
