Results 1 to 7 of 7
Thread: Engine light?
    VN Lukey's Avatar
    VN Lukey is offline BT1, the way to go
    Holden VN S1
    May 2009
    Talking Engine light?
    hey guys i have just fitted extractors to my VN S1 V6 and now and then the engine light will come on and turn off again, sometimes does not even come on? during a 20min drive it would come on and off about 3-5 times..
    what could this be?
    would it be because the extractors? and more flow?
    thans guys.. cheers
    3.8L S1 VN
    Stick Avalanche Champion!
    Jun 2009
    latrobe valley
    im not very good with the technical stuff.. but is there any problems? like are you losing power breifly? or anything like that?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    most likely the o2 sensor cooling down when just cruising if its a long way down the extractors do a code check and see what codes come up
    VN Lukey's Avatar
    Holden VN S1
    May 2009
    im not loosing any power at all.. everything seems fine..
    and as for the extractors the o2 sensor is in the same place as the one that were on the stock headerz...
    my first thought was the O2.. maybie i shoud try replacing it?
    is there anything else it could most probably be? eg.. more flow and the computer has not sensed it and has to be retuned?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    check the error codes and see if any have been stored or you are just stabbing in the dark
    Skidney's Avatar
    Skidney is offline Utes do it better.
    VP UTE
    Sep 2009
    Adelaide CBD
    This happens to me too, my ute has extractors, if im just cruising for a while it will come on for like 10 seconds and then turn off again... weird.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    To check ya ECU.. Read this Topic for the "Error Codes".
    VN, VP, VG and VQ option codes
    Then, this one on how to Check the ECU
    Checking your Computer for Faults (VN - VP)
    Good luck champ!
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. HELP: VT SS Engine light and oil light coming on
    By Evilkio in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-07-2009, 10:36 PM
  3. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  4. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  5. Engine Light and Trac Light
    By Quantum in forum General
    Last Post: 02-06-2006, 11:33 PM
