Results 1 to 8 of 8
Thread: HELP!!! - losing power when opeing throttle
    CommoNdoreVN is offline ginger ninja
    89 V6 VN 5speed Buick
    Jun 2009
    Default HELP!!! - losing power when opeing throttle
    while driving today, car suddenly lost power when accelerating, same feeling as when you are running on almost empty (lumpy) but have plenty of fuel/
    am currently about 40km from home, car will start and run but no power.
    where should i check firs to see if anytthing has come loose?
    oh its a V6 buick.
    its not the years in your life, but the life in your years.
    Vp series 2
    Jun 2008
    fuel pump and or filter.
    when you open the throttle enough fuel is not getting through so the car seem to lack power.
    had the same has and found a blocked filter screen.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Do ya normal check, Pod/Pannel Filter clean.. Fuel Pump/Filter/Lines.
    And, if you can (I will hunt for a guide on how to --) Open your Throttle Body and give it a clean
  4. Default
    With a bit more information I would be tempted to say the CAS. Have you let the car cool down yet to see if the problem still occurs when cold? If it's fine cold, yet starts playing up when hot, it will probably be the CAS.
    Quote Originally Posted by zai View Post
    I am not sutpid
    VP Executive R-spec
    Jan 2005
    fuel pump almost 100%, bash the tank underneath and drive home do NOT stop on your way
    Jun 2009
    foamy it seems your an expert for a reason.
    the fuel pump was getting louder in the last few months, knew it was on its way out, thought that would be the problem. tried leaving it to cool down but mad no difference. got under and gave the pump a whack, made no difference.
    so got the voltmeter out and checked the relay, the pump was only pullin about 1 amp under load, was fine on idle but no good when opening the throttle.
    so new fuel pump bought today, will be back on the road by tomoro arvo.
    cheers for the advice guys.
    VP Executive R-spec
    Jan 2005
    Give credit to centy, he posted first I was just backing him up. I've had a fuel pump fail in the VN so I knew how that goes
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Thank god for JC members!
    My life savers!!
LinkBacks (?)
  1. 08-09-2009, 06:30 AM
  1. Car losing power...
    By Fresh SS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-05-2009, 12:25 PM
  2. vr losing power sub?
    By love the general in forum Electrical Wiring / Questions
    Last Post: 30-08-2008, 12:24 PM
  3. my V6 is losing power.Help !!
    By custom vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2007, 11:01 AM
  4. Losing Power
    By AdamAnt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2007, 12:58 PM
  5. Losing Power
    By My Car Pwns in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-12-2005, 11:33 AM
