Results 1 to 19 of 19
Thread: supercharged fuel injector size
    Vl turbo/ vn supercharged
    Apr 2008
    Kwinana, Perth
    Default supercharged fuel injector size
    gday, are 42lb injectors too big for vn supercharged on 8psi? and are 28lb inj too small? cheers.
    06 VE SS
    May 2009
    Rockingham, WA
    Quote Originally Posted by Jordo2 View Post
    28lb bit to small,iam using 42lb on my vp v6 with powerdyne@5psi and plan to upgrade to 10psi with the same injectors(42lb)
    Apr 2008
    Kwinana, Perth
    Quote Originally Posted by scouser king View Post
    Awesome thats what I had hoped, I picked up a brand new set for 420. Reason being, my car is running 8 psi on buick pos dis charger. It has been pinging even under light loads. In fact I havent put my foot down at all bcos of it. I figured larger INJ would help even things out?
    MR 1JZ's Avatar
    MR 1JZ is offline Classy not sassy
    VU SS
    May 2009
    you will need to tune the car and maybe fit an adjustable fuel pressure regulator to make sure you get a good spray pattern out of larger injectors
    VU SS - The business
    1100ZXi - Water Hoon SPL
    GZ20 Soarer - 500hp 2JZ - Gone
    Apr 2008
    Kwinana, Perth
    Quote Originally Posted by MR 1JZ View Post
    yes, ive got a malpassi rising rate yet to go on aswell, and allready hav a tune but it seems to b tuned 4 lower boost, and am having trouble finding a boost press location on the charger where i can connect a reg and boost gauge to? i dont want to hav to drill out the valley plate. any ideas?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    standard L67 uses 36lbs injectors.
    ditch the rising rate reg, fit the standard reg and get a proper tune to suit the injectors you end up getting
    Body by Holden, Soul by Brock
    the Legend will live forever
    Apr 2008
    Kwinana, Perth
    Quote Originally Posted by immortality View Post
    i prob shouldve asked b4 i bought it
    Apr 2008
    Kwinana, Perth
    does your type charger make more power than mine at the same amout of boost? and if so, why?
    06 VE SS
    May 2009
    Rockingham, WA
    Iam putting down 250ph@wheel(with a shit auto that slips)but i have a lot engine mods as well eg: big lumpy cam ,over size pistons,custom twin mainfols and so.
    VN Wagz's Avatar
    VN Wagz is offline PshhhhHHT- **TuTuTuTu**
    VN Berlina V6 Wagon
    Sep 2008
    Dunlop (North Canberra)
    36lb injectors from a super6 are 370cc, will support (at 80% duty cycle) around 420hp at the crank... you can use either a stock regulator, a rising rate, or a fixed rate reg- mine feeds 1psi more fuel pressure per psi it sees, which is 1:1 preset rate, and apparently helps with tuning due to the base pressure being adjustable (bigger squirters can run well at lower base when chasing higher power).
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    even the stock reg will rise at a 1:1 rate hence why i and a lot of other tuners allways tell people not to replace them the aftermarket regs dont hold constant pressure and can vary from day to day and are badly affected by heat and other weather variables
    VN Wagz's Avatar
    VN Berlina V6 Wagon
    Sep 2008
    Quote Originally Posted by delcowizzid View Post
    I reckon Turbosmart would love to reply to that statement.
    My FPR800 is dead fkn sexy, for that i love it to bits... that and the base pressure adjustment.
    MR 1JZ's Avatar
    VU SS
    May 2009
    when using bigger injectors a small increase in fuel pressure can help obtain a better spray pattern from the injectors...and the same amount of power can be made from less duty cycle...i would agree the rising rate isnt necessary but perhaps an adjustable 1:1 regulator should be fitted
    Apr 2008
    Kwinana, Perth
    did u have to get a different cam to suit boost? or is it an n/a cam grind?
  15. #15
    06 VE SS
    May 2009
    Rockingham, WA
    my cam (so far from stock) was part of a engine rebuild i got done and the blower was put about 8 months later.but some blower set ups dont like lumpy cams.your best bet is check with your local performance shop or talk to the guys on here,iam 100%.
  16. #16
    Apr 2008
    Kwinana, Perth
    cheers 4 that. since im in perth aswell [hamilton hill], do u kno where i can get my delco tuned to run my 42lb inj? so far ive found none in perth.
  17. #17
    06 VE SS
    May 2009
    Rockingham, WA
    I got my vp done at
    Walkinshaw Performance & Formula Tech Dyno Centre
    61 Miguel Road
    Bibra Lake.
    Phone: 08 9494 2424
    there not cheep but they do a good job
  18. #18
    Apr 2008
    Kwinana, Perth
    I got my vp done at
    61 Miguel Road
    Bibra Lake.
    Phone: 08 9494 2424
    thanx heaps 4 that mate, uve saved me alot of dramas.
  19. #19
    06 VE SS
    May 2009
    Rockingham, WA
    it all good hope it turns out ok
  1. 215i injector size??
    By apoc585 in forum V8 Development and Modification
    Last Post: 11-07-2009, 08:59 AM
  2. Supercharged V6 Pulley Size
    By gwb2006 in forum General
    Last Post: 15-01-2009, 07:18 PM
  3. Liquid LPG.. need standard injector size
    By Wrath in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-11-2008, 12:36 PM
  4. Max injector size
    By messymick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2005, 09:08 PM
  5. Injector Size for Commodore Turbo
    By Congo in forum V6 Development And Modification
    Last Post: 09-08-2005, 08:42 PM
