Results 1 to 17 of 17
Thread: VN S1 to S2 intake manifold
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    Default VN S1 to S2 intake manifold
    hi does anyoneknow ifyou can swap to a S2 intake manifold on a S1 motor in a VN??
    like does it bolt straight on and everything lines up?
    thanks for the help guys
    VN Calais With All The Factory Fruit I Need!
    Morton's Avatar
    Fairstar the Funship
    May 2006
    If I remember correctly - no. Some modifications need to be made.
    The 1972 HQ Kingswood
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the only real thing is the PCV valve hole in the drivers side head isnt there on the S1 engine it can be drilled or you can continue to use the VN style PCV setup.apart from that its a straight bolt on will need a S2 radiator too or you will have nowhere to fill the radiator from
    Morton's Avatar
    May 2006
    I was gonna say, didn't the manifold come with provision for the thermostat housing?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    it will bolt up, as delco mentioned you will need to modify the PVC and alter the cooling system to suit. i don't really see the point in doing the conversion though. nothing to be gained from it other then simplifying the changing of the thermostat
    Body by Holden, Soul by Brock
    the Legend will live forever
    в∞ѕтεכ √&
    Jul 2008
    NZ
    it does get rid of that stupid presurised water tank
    VP Executive R-spec
    Jan 2005
    The series 2 manifold is better, it'll be worth a couple HP somewhere, I'd do the swap if I was still V6ing
    Apr 2006
    Auckland NZ
    Quote Originally Posted by greenfoam View Post
    a lot of work for "a couple HP somewhere"
    if your gonna do a manifold swap, turn it around so the TB faces the front of the car, off course to do that you need to move the alternator but that would be a worthwile effort, then you could setup a proper OTRCAI
    VP Executive R-spec
    Jan 2005
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    thanks guys. yeah want to get rid of that stupid water bottle and also the water pipes down the drivers side of the motor as well...makes changing plugs easier and same for fitting the extractors.....that was a pain lol
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    oh and just another silly question..... but i assume i don't need to change to a series 2 computer do i?
    Vp series 2
    Jun 2008
    don't think you have to, but the later tunes are better. greenfoam is the man to ask on that.
    Apr 2006
    Auckland NZ
    no, the s1 has a different cam. will run crap with a later s2 tune. you want a SV3800 based tune to suit yours.
    either delcowizzid or greenfoam or the people to speak too about a tune
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    thanks mate. was just double checking bout the s2 comp. i already got an SV3800 chip in her and love the way she runs now
  15. #15
    VP Executive R-spec
    Jan 2005
    I've not been able to find the specs on the Series 1 cam. I know the one with supposed heaps of lift was only used on early cars, maybe only 88' cars, not all series 1's, there may or may not have been an inbetween cam before the normal V6 cam came around
    The Series 2 VN VP VR cam is as follows (for future reference)
    Made by Cam Dynamics p/n 973221
    Non-Flanged - GM Holden P/N 24503401
    Duration @ .050 Intake 182, Exhaust 190
    Intake Open -21.5, Close 23.5
    Exhaust Open 27.5, Close -17.5
    Lobe Lift intake .2531, Exhaust .255
    LSA 112.5
    Untill Crane went broke this was still made under the Blue Racer name (They bought cam dynamics and kept making them under that name) but I doubt you can get it anymore
  16. #16
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    yeah not sure what mine would be am happy with the SV3800 chip so far anyway. mine is a 1991 S1 with 190 000k's on the clock. but has a S2 instrument cluster in it so i think she was a bit of both right on the change over i guess
  17. #17
    VN S1
    Jan 2008
    The rockers on each of the series are different to, i just had a thought if the series one rockers are a larger bolt width, would it be possible to drill and tap the series 2 heads rockers to fit?
  1. C.O.M.E Intake Manifold.....
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2009, 01:14 PM
  2. [SA] WTB. VP/ VR v6 intake manifold
    By GTP 85 in forum Swap / Wanted to Buy / Trade
    Last Post: 15-07-2009, 10:33 AM
  3. [VIC] v6 intake manifold
    By vr1962 in forum Parts And Other Items For Sale
    Last Post: 10-06-2009, 09:29 PM
  4. vs intake manifold on vn
    By hakhawk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2005, 09:22 PM
