VN series 1, 08-88 to 10-90 uses injector number 0280-150-901 which flows 146.3 GPM @ 3 BAR. Resistance 14.5 ?.
VN series 2, 11-90 to 10-91 uses injector number 0280-150-960 which flows 150.5 GPM @ 3 BAR. Resistance 14.5 ?.
These injectors are also fitted in the
VG UTE 11-90 to 10-91,
VP COMMODORE 11-91 to 07-93 and
VR COMMODORE 06-93 to 04-95.
VT - VY N/A, 09-97 to 06-03 uses injector number 0280-155-777 which flows 150 GPM @ 3.5 BAR. Resistance 12 ?.
The VN - VR injectors are what is classed as an EV-1 injector pintle type which are open to problems when used at an incorrect fuel pressure, hosing is a problem if pressure is too low or too high and the pattern can also be forced too wide for the target area if pressure is too high.
VT - VY injectors are what is classed as an EV-6 injector which uses a multi orifice director plate style technology to better atomise fuel across various operating pressures. These injectors allow more flexibility in relation to operating pressures without compromising spray efficiency or fuel atomisation.
Illegitimi Non Carborundum
