I need opinions! what is the best exhaust for a buick V6 completly stock! and has to be P plater friendly... nice note but nothing to droney
Check out my VP
Wanted to Buy VP Front & Rear Bar/Bumpers
2.5 inch cat back exaust with a 2.5 inch hi-flow cat and some extractors
VN Calais With All The Factory Fruit I Need!
if ur engine is stock and plan to keep it stock ish, dont bother with the highflow cat man
just remove the rear muffler and replace with a straight pipe, the main muffler is enough to keep it legal.
You're probably wondering where you are. I'll tell you where you might be. You might be in the room that you die in. This is your wake up call.
The Daily VN T5V6
355 VN GRP A REP
i run a 2 1/2 redback single muffler it docent drone much unless ya sit smack on 2000 rpm in od mine gos dead quiet
i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
http://robsbackyarddragraceing.bigblog.com.au/index.do
