Results 1 to 13 of 13
Thread: Knocking noise from gearbox - advice plz
    VN Berlina 2L
    Oct 2008
    Default Knocking noise from gearbox - advice plz
    Hi
    I have a 89 Buick V6 with a auto and when I sit at the traffic lights in D and foot on brake with the engine warm there is a loud knocking noise coming from what I think is the gearbox. I have had a look at the harmonic balancer and the rubber is intact and dosent wobble when the engine is running. Is it a worn a torque converter? or something horribly wrong in the gearbox?
    Vp series 2
    Jun 2008
    VN Berlina 2L
    Oct 2008
    Just checked and its not that. Its coming from the gearbox. When I sit at the lights I put in in neutral and the knocking is not as bad. Its when I have my brake on, in drive and the car is warm that the knock happens. Are torque converters known to do this after having a ruff live
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    check engine and gear box mounts
    VN Calais With All The Factory Fruit I Need!
    06 VE SS
    May 2009
    Rockingham, WA
    Quote Originally Posted by KnobMuffin View Post
    Hi
    The same thing happened to me. it was the gear box bolts that there lose.oh check engine and gear box mounts to.
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    as above bolts and mounts possibly the torque converter bolts
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    06 VE SS
    May 2009
    Rockingham, WA
    Quote Originally Posted by rob drag racer View Post
    all so as well said by rod witch i forgot.check torque converter bolts very common issue in high k's vp/vn
    Last edited by scouser king; 10-09-2009 at 01:36 AM. Reason: well because iam a...
    Jun 2008
    golden beach
    rod hay lol
    06 VE SS
    May 2009
    Rockingham, WA
    rod hay lol
    Ha ha its working on the vp to long its killed the last of the few brain cells that i had
    VT SS 5.7
    Mar 2005
    Goulburn
    had same kinda problem,but when giving it a gut full sounded like i blew my bottem end bearings, $20 later had a friend look at it and find my flywheel had lost 3 bolts and was cracked lol
    Real cars don't power the front wheels, they lift them
    VN Berlina 2L
    Oct 2008
    Cheers guys, I am gonna get my car over my mechanics pit in my garage :P and have a look at the bell housing and torque converter to fly wheel bolts. Ill let you know how I get on
    06 VE SS
    May 2009
    Rockingham, WA
    Hope you better than me, i had lose housing bolts witch ****ed my drive plate and gear box
    VN Berlina 2L
    Oct 2008
    It turned out to be the converter onto flexiplate bolts, cheers guys. I pulled my torque wrench out and found most bolts to be within specification so I just nipped them up a little more. There is still a slight knock however its no where near as bad as before, I think my flexiplate is pretty worn as the ring gear has been butchered by the starter so I am going to replace it.
  1. Vp knocking noise
    By Letscruise in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-07-2009, 09:05 PM
  2. vx knocking noise
    By Simonn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-05-2009, 02:48 PM
  3. 253 - knocking noise!
    By dysolve in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-11-2008, 08:23 AM
  4. knocking noise
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2008, 09:43 PM
  5. VR Knocking Noise.
    By AussieHolden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2006, 07:27 PM
