Results 1 to 11 of 11
Thread: removing ignition barrel from vn
    NOT.BT1's Avatar
    NOT.BT1 is offline Bogan pride
    VN exec project vh in the shed
    Nov 2006
    geelong victoria
    Default removing ignition barrel from vn
    hey guys i have been having a bit of trouble lately my ignition barrel is sticking when i try to start it i have to jiggle the key to get it to turn i figure its gotta be the barrel so thought ill just swap it for the one in my spare vn but when i tryed i cant for the life of me figure out how it is removed can anyone shed some light on this for me?
    Quote Originally Posted by neet_wagon View Post
    Instant Failure!
    What exactly IS a VD commodore? Is this some super hektic cop-special I've been missing out on?
    Quote Originally Posted by ari666 View Post
    basically OP is saying he has VD in his crapbox???
    didnt know you could get herpes of the anus, but hey! who am i to judge. have fun with your herpes OP!
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    turn the key to accessories or ignition (cant remember which one), then with a small pin or nail.etc insert it into the small hole on the top of the barrel housing, then simply slide the barrel out.
    before you swap barrels have a look at your key. if the 'cut' is worn on an angle then a new key may fix your problem. no doubt the wafers in the barrel will be worn also but I had the same sticking problem and just got another key cut and its been working perfectly for a few months now.
    My (ex)Ride
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    NOT.BT1's Avatar
    Nov 2006
    geelong victoria
    thanks azzfox i might try the new key idea mine is farely worn even if it doesnt work least ill have a new key for my door locks anyway
    Instant Failure!
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    i just sprayed wd 40 in mine works like a dream now
    VN Calais With All The Factory Fruit I Need!
    -Junior-'s Avatar
    -Junior- is offline <-- Back to Back in 2010
    vn auto
    Apr 2006
    S.W. Sydney
    Quote Originally Posted by LordMayhem View Post
    Will be fine for now, but is the worst thing you can do.
    Wd40 will turn into a mess as dust etc sticks to it.
    Graphite powder only.
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    for the record, you turn it to accessories.
    and when you put the new barrel in, you gotta push down the steering lock inside the barrel housing. you'll see it down towards the bottom of where the ignition barrel sits.
    you push it down towards the floor, and it'll click and stay down, and then the barrel will slide in. sometimes you gotta file some material off from the new barrel so it will fit.
    1990 VN Executive
    Nov 2005
    Quote Originally Posted by -Junior- View Post
    I agree
    VN BT1 Mock Up Commodore
    Dynamic Locksmiths
    NOT.BT1's Avatar
    Nov 2006
    geelong victoria
    thanks for the input guys ive now got the barrel out of my spare car incase the new key idea doesnt work figure ill try it first to make sure that way i wont have different keys for my locks and ignition
    Instant Failure!
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    while ya got the barrel out take it to a lock smith they can code it to use you original key
    1990 VN Executive
    Nov 2005
    I agree with this too
    Dazz
    Dynamic Locksmiths
  1. Easy trick to removing ignition barrel clamps VN, VP
    By churnit in forum Holden Commodore How-To's
    Last Post: 05-10-2010, 04:55 PM
  2. Removing VN Ignition Barrel
    By troy_crees in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2009, 02:34 PM
  3. Removing ignition barrel problem. Help needed
    By MG's VH Wag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2008, 11:07 AM
  4. Removing Ignition Barrel
    By mischf in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2007, 09:21 AM
  5. removing ignition barrel clamps
    By churnit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2006, 08:42 PM
