Results 1 to 15 of 15
Thread: Vibration
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    Default Vibration
    hey guys i had my wagon for over a year now and ever since i have had it. as the converter locks up if you aint on very light throttle you get a vibration like running over the ripple strip wake up lines on edge of the road but twice as loud......am considering rebuilding tail shaft with new center bearings and uni's and am hoping this will fix it even though i can see no wear in the old ones while it is still in the car....any idea's???
    VN Calais With All The Factory Fruit I Need!
    VN_Pretz is offline TNTGMH
    VN S-Pac 5spd V6
    Aug 2006
    Geelong, Victoria
    not sure what the problem is, i have a similar issue, i get a vibration at high rpm, from bout 3,000rpm onwards, not really noisy though, or i can't notice the sound, at 1st i thought it was my extractors cause they're contacting my gearbox
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    yours could be a warped flywheel or clutch/pressure plate
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    are all your engine and gearbox mounts ok ?
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    as far as i know but i will check them in the morning
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    ok well after an indepth inspection it appears that the gearbox is not bolted to the mount at all. so i guess this hopefully is the cause of the vibration. now i just got to remove it all and hope that the reason it is not bolted in is they haven't snapped the bolts off.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    you're telling me. guess considering it was lower 4 inches on cut coils when i bought it last year i shouldn't be suprised hahaha
    Jun 2008
    golden beach
    lol good luck
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    well got the gearbox mount all bolted up now (idiots just didn't bother doing it) so i guess it's down to the tail shaft and uni's....only problem now is said idiots have round the bolts for the tail shaft so now i got to cut them off to get it out.....ugh some people i tell ya!
    Jun 2008
    golden beach
    are ya sure its not a faulty coil mine did that but only when i hit overdrive
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    how would the coil make it vibrate as the converter locks up? as it only does it if you are not on very light throttle?
    Jun 2008
    golden beach
    fair enough i was just adding some things that may be an issue that ive had smiler symptoms with in the past
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    no worries if i get the tailshaft done soon and it still don't fix it then i will sus out the coil pack
  15. #15
    HSV472's Avatar
    HSV472 is offline i just got one
    hsv vr clubsport
    Jun 2008
    s.e melb
    iv hade the same problem as you describe and i got my drive shaft(the one from gearbox to diff) balanced as it was out by 20 grams and it fix the broblem
    hope it helps
  1. VE SS Vibration
    By stu-k in forum VE Holden Commodore (2006 - ?)
    Last Post: 15-10-2009, 12:53 PM
  2. VR vibration
    By dieseldude in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2009, 08:04 AM
  3. VT Vibration at 60-90
    By weblst in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-04-2008, 09:51 AM
  4. vibration
    By bar475 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-02-2006, 09:18 PM
  5. vibration
    By remmie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2005, 06:29 PM
