hey all
I just want to know how much power a T5 could take before it destroys itself. because i plan to stroke my 304 to a 355 estimate about 440 horse's with similar torque. think it could handle that??
VN V6 0-60mph in 7.52
Peter Brock
You can destroy one with a stock 5 litre if you continually launch hard. 355 and they would be marginal. I'd be looking for a 6sp conversion.
Reaper
As above, T56 conversion. Do it once, do it right.
I blew 3 T5s with a stock 5L.
Originally Posted by davway
Exactly, do it once, do it right, TKO-600 without a doubt. T56's are over-rated.
You could build a T5 to handle it... just don't ask the cost.
Hot Lap Motorsport
You could run 1000 hp in a gemini on the street with skinny tyres and not break a T5 :P, but also you could snap one in a stock V6 VQ on the track. Extreme example but the cars weight and the traction play a big part in driveline life. Near stock LS1's snap T56s and tailshafts and axels like they are going out of fashion on the track
Track cars.... we've broken 2 in the last 2 years behind a supercharged VY R8 track car. $12,000 later for a box that so far is going a lot stronger (from the US... bit cheaper then the $30,000 holinger conversion).
There is a T5 running behind a 383 twin turbo pulling 1500hp.
The TKO box is a better option for the fact it's 20kg lighter and costs less to strengthen.
Hot Lap Motorsport
Bah, just put an auto in it....Much less messing around.
*runs & hides from Stealthy*
It all depends how good you are at driving stick, and how you plan to treat it. I thrash the living hell out of my T5, but I rev-match and go a bit easier 1st-2nd when I'm giving it cheek, and it looks after me.
On the other hand, if you plan to flat-shift and clutch-kick, I daresay you won't see more than a few months' use out of it if you're lucky![]()
The 1972 HQ Kingswood
Any update on T5s ? I keep destroying mine and im only making 160 with a cussion button clutch. I rev match alot but some of my mates who have had to drive the car are hopeless
Manual VS T5 : http://forums.justcommodores.com.au/...manual-v6.html
What's required to be modified in order to run a T56 ?
Mal Wood Automotive - Home
Cant remember the exact cost, but it was a few years ago, so you'd be best emailing them to find an exact cost.
Its about 5 ot 6k for a t56 conversion… Was gonna do this a while ago and quoted it and worked out everything you need would add up to about $2500 minus the t56 and labor…
IF ITS GOT TITS OR WHEELS ITS GONNA COST YOU.. ESPECIALLY IF THEY ARE BIG TITS AND BIG MOTORS
MY DAILY NOW WITH ECOTEC CONVERSION
http://forums.justcommodores.com.au/...ml#post2145177
Yeah .... No thanks
I guess il stick with the Old T5 then.
No one has mentioned a dogbox?
To break a T5 you would have to drive like a twat 24/7 imo.
VR and VS error codes:
VS V8 DTC/Error codes comprehensive list.
VS V6 DTC/Error codes comprehensive list.
I reckon it would be worth it.. Better fuel eco (maybe the streets depending on gear ratio) and cause of the extra gear for it to rev lower down the highway. can smash it at the track all day long and it will still shift smoothly the next day etc.. Bit pricey tho but its a good investment
