Results 1 to 10 of 10
Thread: VN Cluster Into VS?
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    Default VN Cluster Into VS?
    does anyone know if there will be any problems by putting my L2 VN cluster into my mums VS? it already has a L2 in it now just it is stuffed and i am putting a L3 into mine so was gonna put my old L2 into the VS?
    VN Calais With All The Factory Fruit I Need!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by LordMayhem View Post
    The wiring is different on the PCB (green backing).
    If it's the speedo that has stopped - swop the speedo's over.
    If it's the fuel gauge - solder up the PCB inside the cluster.
    and 3 Dangerous non ABS VN's
    Vp series 2
    Jun 2008
    if you swap the gausges into the vs cluster it will work.
    you will need to use the vs front and back casings.
    the pcb an warning lights are different.
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    cool thanks guys yeah her odometre has stopped working so might just swap the speedo's
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    normally its just a cog that fails that you can replace, i cant remember who sells them but where cheap.
    88GreenVN's Avatar
    Jun 2006
    You can pull the cog out of the good unit and lube it up into the speedo from your mums car. (the cog sticks and pings a tooth off it).
    Vp series 2
    Jun 2008
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    lol cheaper to put my speedo in as it will just be sitting here doing nothing
    Vp series 2
    Jun 2008
    the vn probably has a green line around the face while the vs will not, thats the only difference
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    nope mine doesn't it looks identical to the vs cluster
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  3. V8 Cluster into V6 VS
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2006, 10:49 AM
  4. led cluster
    By fu2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2005, 02:57 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
