Results 1 to 7 of 7
Thread: vq torque converter clutch
    vq 5.0l
    Sep 2009
    Default vq torque converter clutch
    Hi guys,
    I have read with interest several threads on this and other forums on the subject of vibrations on vn and vp,s. I have a vibration at around 1800rpm and have come to the conclusion it is to do with the torque converter clutch. I originally thought it was the tailshaft, new unis, centre bearing, engine mounts and no fix.
    By disconnectinc the TCC wiring I get no vibration and I am sure now this is where the problem lies.
    The vibration only occurs at minimum throttle and doesnt happen all the time, but can be a pain.
    I am not all that up with it as far as autos go and wonder if anyone may be able to help by answering a few questions.
    1. is the TCC in the torque converter itself?
    2. Is giving the trans a service likely to help?
    3. I read somewhere that the solenoid can give problems, should i try replacing this?
    4. any other ideas?
    Thanks in advance,
    hoots
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    what's the TCC and where did you disconect it from? is that the lock up part of the converter?
    VN Calais With All The Factory Fruit I Need!
    vq 5.0l
    Sep 2009
    Thanks for reply guys, yep replaced gearbox mount.
    TCC is torque converter clutch, there is a 4 pin plug on left of trans that controls the clutch from the ECU.
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    thanks might try un plugging mine as it vibrates as it locks up if you aren't on very light throttle
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    its actually in the torque converter shes a replacement torque converter to fix the issue happens a lot
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    i am hoping putting new uni's and center bearing fixes my vibration but only time will tell
  1. Costs for a Torque Converter Clutch
    By Changa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2009, 09:15 PM
  2. torque converter or something else?
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2008, 06:56 PM
  3. torque converter
    By Matt_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2006, 10:51 PM
  4. Torque Converter
    By vrmusicman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2004, 08:47 PM
  5. Torque Converter Clutch
    By Mad Dog in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-01-2004, 10:45 PM
