Tried to pop the bonnet on the project vn today after the radiator shit itself.
Pulled the bonnet release and ...Nothing - it wont pop it, if we listen when we pull the release we can hear it trying to do something at the front of the bonnet but nothing happens
Ideas guize?
whack the bonnet hard on the corner near the drivers side door as youre pulling it, or else get someone to push down on the centre of it while pulling the release
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
if the cable is streached than replacing it is the only way - but check the catch spring as well as this can stop the bonnet from opening too.
and 3 Dangerous non ABS VN's
heat may have stretched the cable...also try holding the release cable on the white plastic as you open it as they can flex there to
VN Calais With All The Factory Fruit I Need!
id say its gone out of alignment due to the rad exploding as stocky said whack the drivers side wile pulling the release
i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
http://robsbackyarddragraceing.bigblog.com.au/index.do
if not get a big flat head screw driver and go under ya car. Look 4 a hole where the bonnet spring is and undo it. Thats how i got mine off when my cable snapped.
Wrecking VL factory V8 only a few bits left still have full dash/crash pad
and have a vk 202 motor and 5 speed Make an offer want it gone
DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
Originally Posted by Reaper
