Results 1 to 7 of 7
Thread: Vn Front Strut replacement help
    Vr S2 Calais
    Jan 2009
    Default Vn Front Strut replacement help
    hi all well im replacing my front struts what else would i need to replace aswell while im doin the struts as my mate said i will need to replace bearings also would i need to do a wheel alignment cheers for all the help
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    just make sure to mark how the strut top bearing plate sits in the tower before you pull it out then your wheel alignment will still be fairly good
    VN Calais With All The Factory Fruit I Need!
    Vr S2 Calais
    Jan 2009
    with the top bearing plate are these bearing replacable or do i have to buy the whole strut bearing plate
    Vp series 2
    Jun 2008
    Vr S2 Calais
    Jan 2009
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    depends where you get them and if they are standard ones or say one's from nolathane but 200 should see you right either way
  1. vb front strut
    By linejockey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-10-2008, 03:48 PM
  2. Front Strut inserts
    By manualwagon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-10-2007, 09:43 AM
  3. front strut shudder...
    By vnstu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-06-2006, 06:47 PM
  4. front strut question
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2006, 06:51 PM
