Results 1 to 4 of 4
Thread: VQ V8 fuel pressure regulator
    vq 5.0l
    Sep 2009
    Angry VQ V8 fuel pressure regulator
    Hi guys,
    I have a VQ Statesman dual fuel, when I got the car it wouldn run on petrol, replaced the pum and all was good. A bit later down the track I noticed that it wouldnt run on fuel properly, like it was starving for fuel, rough running, popping in exhaust and gutless between 1k and 2k revs but oddly ran better above 2K but still gutless.
    So I changed the fuel filter, ( i know, should have done it before) problem still there.
    When I pulled the old filter out it rattled! oh no! cut it open and the paper element hat seperated from the can and all the rust and crap that was in there has gone through the fuel system.
    As it idles ok and seems to run ok under no load i suspect the injectors are ok and fuel pressure regulator is full of crap.
    Before I replace it ($130) I thought I may be able to clean it out by removing it and washing or back flushing it. I am not sure how it seals into the fuel rail.
    So, some questions.
    1. how does the regulator seal? orings? ru usable?
    2. any way of testing it? (dont have a pressure gauge)
    3. any way to get the crap out of the system or will it all be gone as I have a new filter?
    4. Runs perfectly ok on gas, no error codes either so has to be fuel?
    Thanks for your help, great forum, can ususlly solve most problems by searching and have learnt a lot from this site.
    Cheers, Hoots
    VN LUVA SA's Avatar
    VN LUVA SA is offline VN LUVA SA
    VN HTD 89 Aero
    Aug 2009
    South oz is a small place
    Default u can blow out the fuel reg with a air compressor but u can find new 1s on ebay $40
    Quote Originally Posted by hoots View Post
    Hi guys,
    So, some questions.
    Cheers, Hoots
    Ebay they got em for $25 pretty sure,just got a v6 bosch 1 for 40 but i was in a rush! :0
    Aug 2004
    vq 5.0l
    Sep 2009
    thanks guys, will do
  1. Fuel pressure regulator
    By chromic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2011, 08:35 PM
  2. Fuel Pressure Regulator
    By 5 speed VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2008, 10:46 PM
  3. fuel pressure regulator
    By mason_luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-09-2007, 10:28 AM
  4. Fuel pressure regulator
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 10:19 AM
  5. Fuel Pressure Regulator
    By vl 88 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-01-2007, 11:46 PM
