Results 1 to 8 of 8
Thread: Setting an L3 cluster to work with Gas
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default Setting an L3 cluster to work with Gas
    I've got the VN Calais running on gas and the trip computer functions are not accurat at all. The DTE slowly increases with each tank.
    Now the car runs mainly on gas now so I was thinking I should set the trip computer up to reflect the gas used.
    So can we use the gas tank gauge (volts) to fix the tde?
    Flow rate is no problem and can be adjusted to suit gas usage.
    Distance would stay the same.
    and 3 Dangerous non ABS VN's
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    I attempted it back then, I couldnt do it, unless I had some new fancy gas system.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    88GreenVN's Avatar
    Jun 2006
    I was thinking of taking the wire from the fuel gauge sender and connecting it to the gas tank. Would this work? Just do away with the fuel tank altogether or even have a switch between the 2.
  4. Default
    hmm, i don't think you can just grab the wire and connect it straight up. when i got gas installed in my car, i initially wanted the gas to show on the fuel gauge on the dash. when i got my car back, they had installed a separate gauge, because they didn't have the right 'part' to connect it up. i can't remember what exactly it was that they needed to get the gauge working on the dash though.
    i was always interested to find out, did your AVG and fuel used functions work after all?
    edit: have a look at this, might give you some ideas: http://www.aulro.com/afvb/technical-...lpg-gauge.html
    Quote Originally Posted by zai View Post
    I am not sutpid
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by levymetal View Post
    edit: have a look at this, might give you some ideas: LPG gauge - Australian Land Rover Owners
    I think you can adjust the flow rate to be spot on with the AVG used. But the DTE keeps going up as the car has the same amount of petrol in the tank if you use gas 100% time.
    So the main issue I can see is converting the gas tank gauge signal (assumed to be volts) to be the same as the petrol gauge (which is volts).
    LOL - just read that link levymetal and it's ohms.... what ever they are....
    VP Exec
    Jun 2005
    Quote Originally Posted by 88GreenVN View Post
    The switch should be doable. Use a 5 pin relay actuated with the fuel changeover switch to switch between the output from the LPG and petrol tank senders.
    The gauge senders, petrol and LPG, have resistances in Ohms that vary with tank level. A voltage into the sender will drop across the sender in proportion to the resistance, meaning a lower (signal) voltage out. (There will be another resistance in the circuit.) A search for "series DC circuit" on wiki or similar might help.
    Assuming that the voltage into the petrol and LPG senders are the same, you will need to check that the sender you have now matches the petrol sender in resistance or if not find one that does. The resistance ranges - mentioned in the link above - are printed on the bottom of face of the little gauge, which is also the sender, inside the compartment on the LPG tank.
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    Ohms are the resistance, just as Volts are pressure and Amps are flow. Hope that helps a little bit.
    88GreenVN's Avatar
    Jun 2006
    I pulled a level 3 loom out of a gas powered VR last week and it had a wire from slot 20 on the 4th plug instead of the tan wire in slot 11. I just can find where the new wire went to. The interesting thing is it used slot 20 on the 4th plug. I need to find out where this wire went to and what slot 20 feeds to on the cluster.
  1. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2011, 10:33 AM
  2. Level 3 Cluster Setting Questions
    By nugatory in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-10-2009, 08:13 PM
  3. Level 3 Cluster - Odometer Setting?
    By OzJD in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2009, 11:57 AM
  4. air con dont work on setting 4 but blower does! VS
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2008, 12:41 AM
  5. Setting Km on new dash cluster
    By achimw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-02-2006, 07:00 PM
