Results 1 to 9 of 9
Thread: some help
    vt executive station wagon
    Jan 2008
    Default some help
    hi everyone
    just a quick question
    i have a vn commodore and today one of the dash lights came on and have no idea what it means
    its the one the looks like a ! its in a circle and then a set of brackets around that
    any info on this light would be fantastic
    thanks in advance
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
  3. Default
    doesn't that mean handbrake? i forgot, and it's too cold and wet outside to get my manual
    Quote Originally Posted by zai View Post
    I am not sutpid
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    went and checked then, according to car manual its brake failure
    it should come on when you turn the key to acc but not be on while driving
    The Black Beauty
    Jan 2008
    brake failure... hmmm strange....
    the brakes seem to be working fine.....
    would it be possible for water or dirt to get into the sesor and its giving a false reading?
    had to go down a dirt road today and as it has been raining where i am... there was a couple of puddles i couldnt avoid
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    Quote Originally Posted by sv0478 View Post
    possible, but ive done plenty of offroading in my car and never had it happen, best to get it checked, dont want to risk it when it comes to brakes
    The Black Beauty
    VS Berlina 3.8
    Dec 2008
    If it's anything like my mates Kingswood, it's just something that tells you when you need new pads or rotors. Don't really remember how it works, but your rotors or pads might be a little on the thin side.
    So, it wouldn't really effect your braking, but it might be time to give them a look over.
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    Quote Originally Posted by TVR-161 View Post
    my owners handbook sez the same
    if my scanner was working id start uploading pages
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    Jan 2008
    ok well thanks all for the info
    if its still the same tomorrow i might get it looked at on monday....
    might also just check the pads and see what condition they are in
