Results 1 to 6 of 6
Thread: Replacing CAS
    n/a
    Sep 2009
    Default Replacing CAS
    Im looking at replacin the CAS on my S1 VN this weekend to see if it'll resovle the cutting out issue ive been having... is there any trick to putting it on eg: is there a write up or something?
    i know its behind the balancer and im prepared to struggle with the crank bolt ... but is there anything i should know?
    Thanks!
    n/a
    Sep 2009
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    not really anything much can go wrong just make sure the fins on the balancer are all straight and arnt hitting the new cas when the balancer turns and you cant go wrong the s1 version cas is adjustable in and out to get clearance for the fins
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    just like delco wizzid said make sure the fins are right and adjust it right other wise ya will smash the new one i tend to take the bracket off with the old sensor in it still and mark where its positioned to make it simpler when putting it back on
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    n/a
    Sep 2009
    thanks guys... ive also been told to redo the timing when i replace it... should i?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if its v6 you cant actually set timing cause the cas only goes on one place
  1. Replacing MAF with MAP on a VS
    By ephect in forum Tuning
    Last Post: 30-06-2009, 06:00 PM
  2. Replacing oil switch (ebay one) and replacing cup holders???
    By BlackCaprice in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-06-2009, 03:50 PM
  3. when replacing a cam
    By mofo sixx in forum General
    Last Post: 24-03-2009, 10:34 PM
  4. replacing hu on vt
    By roby02 in forum Car Audio
    Last Post: 20-09-2007, 09:01 PM
  5. Replacing 3.8L with 5.0L!!! Help?!?!?!
    By Berlina... in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2006, 09:45 PM
