Results 1 to 6 of 6
Thread: eaton m67 swap to m90: differences
    Vl turbo/ vn supercharged
    Apr 2008
    Kwinana, Perth
    Default eaton m67 swap to m90: differences
    gday, i have a VN v6 buick that i have supercharged with the Eaton M67 [the predecessor to the M90]. to fit this i had to make a new intake pipe that bolts up to the back of the charger so it would clear the firewall. if i were to fit an M90 would i have the same problem? or worse?? as i havent been able to compare the physical sizes of both. Also, is the position of the M90 bolt holes the only difference in comparison on the M67 base plate that the charger mounts to? cheers.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    For all the info on the L67 M90 go here.
    www.l67torque.com • Index page
    The Australian M90 has a inlet bend already attached on it.
    The US m90 inlet is straight out the rear and too long to fit in our engine bays.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Apr 2008
    Kwinana, Perth
    Quote Originally Posted by Surfwagon View Post
    sorry i made a mistake, my charger is the m62. and im asuming u have a later model commo which seem to have more room at the firewall [correct me if im wrong]. do you kno if the aust m90 will clear the firewall of the VN without modding?
    VS Berlina 3.8
    Dec 2008
    You are probably going to have problems closing your bonnet. Most of the M90 VN conversions are just an entire L67 transplant, so if you go to the aforementioned site, you might be able to see some VN's with the L67 setup, there shouldn't be much of a difference about where the blowers and engines sit.
    VS l67 statesman
    Dec 2008
    Quote Originally Posted by Jordo2 View Post
    Listen to surfwagon ,thats his new car in the avator and if you jump onto the other forum you will find out everything there
    Apr 2008
    Kwinana, Perth
    Quote Originally Posted by vsl67 View Post
    thanx 4 the help guys, i'll check that out.
  1. Eaton M90 on VN S1
    By orlando in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2009, 09:06 AM
  2. eaton m90
    By BL36wn in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-07-2008, 08:28 PM
  3. [FS: VIC] - Eaton M45 Supercharger
    By matt08 in forum Parts And Other Items For Sale
    Last Post: 03-04-2008, 10:56 AM
  4. Eaton M90 VP
    By warniee in forum V6 Development And Modification
    Last Post: 04-07-2006, 11:13 PM
  5. Eaton M90 SC or CRS SC?????
    By CustomVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2005, 11:08 PM
