Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: VS engine into VP Commodore
    VP Commodore
    Sep 2009
    Hervey Bay, Queensland
    Default VS engine into VP Commodore
    Hey guys, ive just put a VS ECOTEC V6 into my VP commodore, ive changed over the computer and the wiring harness, but the bastard won't start, it turns over and ive already checked for a spark, which is there, so i can only assume that the injectors aren't working? Has anyone done this conversion before? Any help would be awesome! Cheers
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    do a search theres a few that have here
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    vx berlina
    Apr 2009
    vic
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if you didnt fit the BCM and key reader and use the vs key it wont go unless you have a memcal with the security disabled so it doesnt require these extra parts
    VP Commodore
    Sep 2009
    Quote Originally Posted by delcowizzid View Post
    I only put in the computer and wiring harness, would i need to use the vs key? or could i stick with the vp one? I was under the impresion that if i put the vs computer and wiring into it, that it would just run off that. Is this right?
    I'm living in Hervey Bay mate
    VT SS 5.7
    Mar 2005
    Goulburn
    Wokka01, Do you happen to have any pics of the converrsion you could post up as im thinking of doing the same conversion, also post up any problems u have had etc cheers mate
    Real cars don't power the front wheels, they lift them
    VP Commodore
    Sep 2009
    Yeh mate for sure, ive only got a couple pics though. I'll try and get them on here ASAP.
    Pretty much everything mechanical was a piece of piss, ive got the VP auto bolted straight up to the ECOTEC, obviously i had to use the VS exhaust headers, but they fit straight onto the rest of the VP exhaust, ive had to change over fuel lines, power steering lines ect, the only problem ive had is that after putting the VS computer and harness in, ive found out that the ****in thing wont start, apparently it has something to do with the VS computer or something, i was havin a look at some other threads and saw that its possible to run the VP computer and harness, but ive gotta look into that some more so im certain that i can do that.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i can do a chip so it runs without the keys and BCM mate if you get stuck
    VT SS 5.7
    Mar 2005
    Goulburn
    im guessing BCM would be (Body Control Modules) ?
    VP Commodore
    Sep 2009
    ok cool, well i'm not the smartest person on the subject, so i dont exactly know how it all works, but would the chip be used for the VS ecu? Or would it be easier to use the VP ecu and harness and just get it tuned? I dont really mind that i wont have sequential fuel injection as its just a daily driver
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you have to add the vp knock sensor coolant sensor and inlet air temp sensor if you use the vp ecu .also the vs ecu wont work the torque converter lock up and the speedo sensor wont work either
    VP Commodore
    Sep 2009
    ok so it would just be easier to use the vp ecu, and transfer those sensors from the old engine?
    If so, and i know this is gonna sound a bit daft, but those sensors would be located where exactly?
    Vp series 2
    Jun 2008
    Air temp sensor is on the back of the inlet manifold and the bits off the throttle body. All my books say the temp sensors have the same rating so would not bothe changing it.
    VP Commodore
    Sep 2009
    ok cool, so basically just the knock sensor needs to be transferred then? Is there nothing else at all that needs to be changed over? Sorry if i seem to be repeating myself, i just want to get all the info i can before i go pulling stuff off it again and ****ing something up.
  15. #15
    в∞ѕтεכ √&
    Jul 2008
    NZ
    theres a few good write ups on here hozy added one today on this very topic im sure. you need the inlet air temp sensor from the rear of the vp manifold under the neck for TB you will need to drill and tap the ecotech inlet manifold for it to screw in. the knock sensor is easy remove one and replace with vp one and unplug the second one its a mission with the engine in .some say the vs coolant sensor is ok some dont i just did VS to vr auto ecu and the sensor didnt seem to read right and was a bit broken so we changed it the adaptor can be bought for cheap it just screws in the factory hole and has a smaller thread for the vp sender and it saves fitting the correct plug onto the vp loom as they both run different plugs so you cant use the wrong sensor leave the cam angle sensor above the waterpump unplugged as there will be no plug for it and its not needed. i think thats about it
  16. #16
    VP Commodore
    Sep 2009
    ok awesome, ive got a mate who's an auto electrician, so i think i might have to recruit him to give me a hand with it all. But otherwise cheers heaps for the info, i'll keeps you's updated on how i go with it, and Madsav, i'll keep trying to upload those pics for ya, my internet is being a little bitch at the moment
  17. #17
    Vp series 2
    Jun 2008
    iac and tps are different on the ecotecs to so you may need to use them off the vp aswell.
    (different as in wired back to front)
  18. #18
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by centy View Post
    Wired back to front? lmfao
    How about you just use these...
    Guides For Ecotec Into VN/VP [HERE]
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
  19. #19
    Vp series 2
    Jun 2008
    when you compair the wiring diagram for the tps and iac they have the same ratings but the pins are allocated to components.
    They would work but the pins on the plugs would have to be swapped around to suit them and i just can't be bothered.
  20. #20
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    So obviously you didnt look at the link I posted.
    *sigh*
  21. #21
    VP Executive R-spec
    Jan 2005
    I would suggest to get it running, run a VS manual tune with the immobilizer disabled. Maybe think about a VN loom later on, not sure how the speed sensor will go with that but maybe the getrag one is compatable?
  22. #22
    VP Commodore
    Sep 2009
    I just had a look at your link hozy, and i seem to have most of it sorted, but i was originally thinking about hooking up the VP ecu and harness and changing over plugs and lengthening wires wherever needed. Would this not work at all?
  23. #23
    VP Commodore
    Sep 2009
    Ok, sitrep, ive gone with the VP harness and computer, and the engine has come to life, YAY! only problem is, the revs are fluctuating between about 1000 and 1500 rpm, the first few times i started it, it would run for a bit, but as soon as i touched the throttle it would stutter and stall, im guessing this could be because the engine hadn't been started in a couple months, after a few more goes it started up fine and kept running, apart from the revs, the check engine light in the dash cluster is on and so is the battery light, any ideas?
  24. #24
    Vp series 2
    Jun 2008
  25. #25
    HICOMPVN's Avatar
    HICOMPVN is offline Wanting That Lil Bit More
    VN Commodore Executive S1
    Mar 2006
    S.E SUBURBS
    HAHAHA
    yeah there are NO error codes, it's the O2 sensor, i know got the same prob, i bet if you do an error code check it'll come up as 12, and or 42/43/44
    the ecotec is a lot cleaner than the buick (vn) and there is more oxygen in the exhaust that's y the check enging light is on, so in a way all it is, is that the vn/vp o2 sensor range is not good enough. If you need any help at all buddy you can contact me, as for i have a vs ecotec in my VN, running VN computer and all vn sensors, except for CAS and DFI those two are from the vs!!
    you can see my girl here
    YouTube - HICOMPVN'S 1990 VN Commodore Exec Sedan V6 With A VS Ecotec Engine!!!
    also the idle is due to the ecu mapping, it needs to be reflashed/retuned to the vn/vp chip but run good on a standard tune, but be mindfull of pinging at full throttle under load, will ping bad, as for the vn/vp tune runs rich down low, then leans out at top end.
    hope that helps
    Hicompvn
  1. Vr commodore engine problems!!! Help
    By t_vrexcommodore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2009, 10:03 PM
  2. vp engine into vr commodore
    By cruzn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2009, 05:10 PM
  3. vp commodore engine change over
    By shane_uns in forum V6 Development And Modification
    Last Post: 25-11-2008, 05:23 PM
  4. Engine Noise - VS Commodore
    By centauris in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2005, 10:09 AM
  5. Vt Commodore ( Engine Stopped )
    By rocketman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-12-2003, 07:18 PM
