Results 1 to 6 of 6
Thread: Engine Problems
    87 VL Calais Turbo
    Mar 2009
    Default Engine Problems
    Hey there,
    Just bought another VN (yet to post pics of it).
    Is great condition with crap loads of extras except the engine is another story. The engine is 270,000+km and the odo has stopped. There is a weird but fairly loud rattle when the engine is running and it runs with the speed of the engine. Like when the revs are high it will rattle or click will get faster with the engine. Another thing that has started to happen in the last 2 days is when i try to start it when its cold it lets out a loud hiss from the engine and just stops, usually followed by me not being able to start it for the next 20 seconds or so.
    The previous owner says it was the engine lifters and before i go get it checked out i thought i might aswell post it here first.
    When i find the problem im either going to fix it or just swap the engine from my brown VN.
    What do you all think?!?
    Thanks
    James
    I build websites for cheap.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The rattle could very well be the harmonic balancer, they sound like something inside wants to get out when they rattle.
    The sound is vacuum through the intake, does it still turn over though? Could be a leaking injector.
    Visit my Facebook page
    87 VL Calais Turbo
    Mar 2009
    Yes it still turns over but it does not start. When it happens i just turn the key off. Sounds bad
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Because the engine doesn't fire it is just intake noise. The engine will rotate backwards a touch and hiss through the intake.
    This could be happening because there is too much fuel in the intake from a leaking injector.
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    Quote Originally Posted by swiftymcfeat View Post
    Hey there,
    James
    this may also be the tensioner pulley as well
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    1989 VN Berlina
    Jul 2008
    Gladstone, Queensland
    If its a rattling noise that increases with engine revs then Im certain its your timing chain. The small spring tensioner that keeps the chain tight has most likely broken off like it did in my VN. I doubt its the harmonic balancer, but a easy way to check it is to try turning it by hand. It should be IMPOSSIBLE to move it but if it moves at all - even the slightest bit - its stuffed. I'd also take the belt off to check this. Hope that helps
LinkBacks (?)
  1. Engine problems
    By ST.47.ES in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2008, 06:33 PM
  2. vt engine problems
    By peter white in forum VT - VX - VU - WH - V2
    Last Post: 31-08-2008, 05:30 PM
  3. 94 VR Engine Problems
    By VR Rules in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2008, 02:32 AM
  4. Engine Problems
    By Holmez in forum V8 Development and Modification
    Last Post: 10-10-2007, 12:25 PM
  5. 253 engine problems
    By src308 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-02-2006, 07:54 PM
