Results 1 to 3 of 3
Thread: Clutch pedal problem!
    VG
    May 2009
    Grafton
    Default Clutch pedal problem!
    Noticed clutch pedal on my vg ute other day doesnt spring back like use to.. had a quick look and found the spring on pedal is broken..
    How do i go about getting to it and replacing?? What needs to be done?
    rickybobby's Avatar
    rickybobby is offline shake 'n' bake
    VN S1 V6 T5, VR V8 T5
    Aug 2008
    MEL
    find manual commo (up to vs series 1) with spring at wreckers (good luck)
    or
    order holden spare parts clutch pedal spring
    part no. 92031795
    cost about $5.95 (3 weeks ago) same day delivery
    should be able to install diy or very cheap and quick (free) for mechanic buddy.
    inside car under steering wheel undo nut/bolt clutch pedal to pedal box
    the new part or spring (to be replaced)
    - loops around pedal pivot shaft
    - hooks around pedal shaft at lower or foot end
    - sits inside top of pedal box at upper or steering wheel end
    - sounds strange but this spring forces pedal towards engine (or downwards to floor)
    the clutch cable from pedal to gearbox sits in hook at very top pedal shaft and forces pedal towards drivers seat but shouldn't need to be messed with if you don't move pedal around too much when slipping the replacement spring on.
    VG
    May 2009
    Grafton
    Thanks for that.
    will go get part tomoz. Sounds simple!
  1. Clutch pedal loose
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-08-2009, 10:19 PM
  2. t5 clutch pedal again
    By VSEXEC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 07:28 PM
  3. Wtb:vs Clutch Pedal
    By janhdt in forum Swap / Wanted to Buy / Trade
    Last Post: 25-11-2007, 12:43 PM
  4. squeaky clutch pedal
    By dandandaniel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2006, 09:26 AM
  5. Clutch Pedal Spring
    By mephisto in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2005, 07:18 AM
