Results 1 to 7 of 7
Thread: Tightening bonnet cable
    dans_vz's Avatar
    dans_vz is offline formerly vp_berlina
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
    Default Tightening bonnet cable
    How do I tighten the bonnet cable?
    It seems really loose when I pull on it to pop the bonnet, and some times when Im driving the bonnet pops up onto the latch.
    Thanks
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    we recently had a problem with the vn where it wasnt tight enough to pop the bonnet.
    just find the cable and find a few places where u can cable tie it to put pressure on it
    The Black Beauty
  3. Default
    i don't think you can tighten it, but another option is to just tie a knot in it. worked for me
    Quote Originally Posted by zai View Post
    I am not sutpid
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Quote Originally Posted by levymetal View Post
    like I did with my throttle cable
    The 1972 HQ Kingswood
    dans_vz's Avatar
    Aug 2006
    Albury/Wodonga
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Quote Originally Posted by Morton View Post
    LOL, levy & mort!! Good to see the true Commodore spirit
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    VP Exec
    Jun 2005
    On the radiator support there is - or should be - a little metal bracket for the cable held in place by a (6mm head?) coach screw. If the outside of the cable hasn't slipped or been damaged too badly, you can loosen that off and pull the cable tighter. (Too tight when doing up the bolt will crush the outside of the cable onto the cable = sticking.)
    If the cable feels loose and the catch won't hold it's possible that the catch is sticking, perhaps something is bent. That can be caused by levering open the catch on a bonnet that won't open with the cable.
    Another possibility is that the catch has been adjusted so as to allow the bonnet to be opened with a stretched or slipped cable => adj. bonnet catch after fixing the cable.
  1. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  2. 95 lexcen bonnet cable will a VR cable fit?
    By Gazza2005au in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2009, 04:19 PM
  3. bonnet cable
    By zohpm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-04-2007, 04:12 PM
  4. Tightening bonnet hinge(body end, not bonnet end)
    By NOGEN 3 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-03-2007, 11:28 AM
  5. Tightening Accelerator Cable
    By Simdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 06:15 AM
