noticed in the fuse box that my high and low beam fuses are melted to the plastic anyone else had that problem?
Real cars don't power the front wheels, they lift them
was useing the ultra white globes , but i think i also had a set of red and blue flashing parkers at sum point that could have caused the problem
yes, just fixxed it but lights still drawing a little more power then they are meant to.
i removedthe fuse panel and all the wires running to it from a wreak.
not a lot there. big red wire goes under the engine fuse block and a couple smaller wire go out onder the relays.
then just replaced them and put in 20 and 30 amp fuses.
I can not find a short so think maybe there is a problem inside the head lights.
when head lights are unplugged the multimeter say open circuit so head lights are the problem.
