Page 1 of 4 1234 LastLast
Results 1 to 25 of 82
Thread: Whos got an LSD/minispool?!
    vn ss hdt aero
    Sep 2009
    Default Whos got an LSD/minispool?!
    Hi.
    I'm currently torn between a mini-spool and mechanical LSD (clutch packs, like kaaz etc)
    my mechanic is scaring me with prices, and I'm interested in what you fellas paid for your LSD's if you got one fitted, or heard about others doing it.
    I curious about how bad minispools are on the road. My vn is not a daily driver.
    If im coasting around a corner with a minispool, is it likely my rear end is going to slide out on me?
    EDIT: Also diff gears. I'm looking to get 3.7, and my mechanic told me they're around 700bucks brand new. WTTTTFFFFF
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    mischa on here just got a LSD and 3.45 diff gears done for 500 bucks ish
    The Black Beauty
    vn ss hdt aero
    Sep 2009
    Quote Originally Posted by TVR-161 View Post
    What make lsd? I'm not interesting in the cone/viscious ones
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Fitted a minispool a few weeks ago. Dont listen to people who tell you they are dangerous because they are NOT. I only have soft 205's on the rear and the car will not slide out just by turning sharply. I did some 'testing' in a secluded open bichamen area just to be amazed how well the car still sticks. Ive never had any problems in wet nor has it stepped out unexpectedly EVER. I can still corner sharply at 100k's with no problem at all. Most of the time you forget you even have one... until it comes to parking. But you get over/used to it.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Quote Originally Posted by azzfox View Post
    Agree with everything you said. I had a mini spool in my car and not once did it 'lose control'. I wouldn't recommend a mini spool in a daily driver, LSD is much nicer for low speed corners and reversing. You can get LSD centres off ebay for around $300.
    vn ss hdt aero
    Sep 2009
    My mechanic isnt a franchise, he works from his home. Why would his pricing be so high. He charges F all for everything else he does, (gearbox rebuild, clutch, servicing even hydraulic handbrake)
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    I got my LSD freshly built with all new internals, all installed cost me $550 i think. was in there for about 6 months and wasn't as good as i expected it to be, so i got a spool fitted. That cost me $270 all up including all new bearings.
    The spool is a bit annoying at real low speeds, but overall its really great. If its not a daily, then i highly recommend it! I'm putting the LSD i took out into my daily car.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VN_chris is offline Banned
    VN Commodore S
    Jul 2009
    Wollongong
    I had the holden factory LSD fitted a couple of weeks ago, it cost $237 to get the centers swaped over.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    A spool can be a bit understeery in some conditions, but in normal driving conditions it's far more predictable than an LSD, especially a worn LSD.
    The 1972 HQ Kingswood
    vz ss and vs statesman
    Mar 2009
    i agree i jus put a spool in mine the cornering at low speeds is annoying but they dont spin out or any thing like that if anything it sticks a bit better than my old diff to the ground just my opinion
    Mar 2009
    it only cost 550 and i put it in myself just bought the whole unit off ebay wasnt to hard
    vn ss hdt aero
    Sep 2009
    Yeah, I was all for a minispool, until a mate at work scared me with his experiences in them.
    I just thought about it for a minute, and realized; He wasn't doing the driving, the lockers were in a different car, the guy driving was probably flooring it on purpose.
    Plus, I don't have time to root around with finding the best priced LSD in town, I have a deadline to meet, and the car has to be functioning well for what its going to be put through....
    A quick question to those in the know, would it be worth throwing in new axles with a minispool, since they are going to be the weakest link?
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by flanker View Post
    meh mine were still in perfect condition so I reused them. wouldnt mind pulling one out to see how theyre going though. but I doubt the minispool alone will cause them to wear/twist/whatever.
    My (ex)Ride
    vp
    Sep 2008
    how much does it cost for a mini-spool wouldnt mind puting one in my car as my lsd is starting to play up
  15. #15
    VR Calais 5lt
    Sep 2009
    im keen to check this out. currently have a single pegga in my calais.
    why an lsd was optioned ill never know!!
  16. #16
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Got my Mini spool new off ebay $40 a skyline diff full with eveything $100, and did all the bearings in my diff, my car kicks out very easy with 245 18s, but it is supercharged so and manual, without the charger it still kicked out easy aswell, but for what you pay for them they are great and as Morton said they are predictable and when you get the hang of it they are easy to drive/drift if you must, over an LSD, well worth the money, parking is fine i am over it lol, and its my daily aswell, but in the rain i dont bother bringing my car out, just jump in my mates SillyCar (celica).
    ~ VN POWER ~ Click the scales
  17. #17
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    I payed about $80 posted from ebay. Great value for money compared to a decent LSD/locker setup and always have 50/50 drive to each wheel. And yes it makes the car easier to slide around (using throttle) but also easier to control with a bit of practice. Another thing I noticed though is steering becomes a bit heavier as the rear wheels are trying to keep the car in a straight line, but you get over that too. Its also my daily/only car.
    I think Ive given enough praise now
    My (ex)Ride
  18. #18
    Black VN MANUAL
    Feb 2007
    Top of Vic
    When i go into a car park and pull in, and when the wheels are locked nearly the car will roll back when i put the clutch in lol, dunno if its strain on the axles or what.
  19. #19
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    No doubt just loaded up control arms. Stock bushes are quite flexible.
    My (ex)Ride
  20. #20
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Took the words right out of my mouth.
    Quote Originally Posted by Morton View Post
    This is right, it does make it understeer a bit worse but i noticed it is no where near as bad when your off the throttle... Dont know how that works lmao
    so depending if i need more understeer or over depends if im on the throttle
    1. If you want to change axle's then go for it, just think of it as a security measure but the spools do alright with 28+spline axles, i have had the spool for almost a year of daily driving and parking pretty much everyday and there not stuffed yet haha
    2. As people have said, slow speed parking is a bit weird when you first get it installed but you get used to it... its one of those things that you think "Is the shit parking worth having insane control and predictability of your car?"
    AND you can minimize the skipping etc by putting on a nice set of sticky tyres
    3. I could garentee almost everyone with a spool has giggled like a girl the 1st time they got it sliding, sooooooooooooooo easy and fun!
    BTW i would recommend you get one if it was a daily but since its not a daily. 100% get one you wont look back!
  21. #21
    vn ss hdt aero
    Sep 2009
    Hey guys, the responses have been very helpful.
    I just bought a brand new minispool and brand new 3.7gears
    we'll See how I go
  22. #22
    VN Commodore S
    Jul 2009
    Wollongong
    How would the cops go about cheking if you have a minispool fitted? has any one ever been busted?
  23. #23
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Probably just a defect? (i dont know lol)
    I dont know anyone who has been caught but i guess you could say it is a very tight rebuild lsd or say you brought it like that? doubt your chances that they will believe you but its worth a shot lol
    btw you will love the spool and gears
  24. #24
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    They cant really check without jacking up the rear end, or asking you to perform a turn for them which Im not sure if they can do that. But if a cop becomes suspicious and asks me whats going on, Im just going to play dumb. I even put the old rusted tag back on the diff cover to give it that untouched look.
    My (ex)Ride
  25. #25
    vs 5L ute and vh project
    Evel Cownievel Champion!
    Dec 2008
    NSW inverell
    im lookin at a mini spool 4 my ute as there a bit lighter than a sedan in the ars should i get one
  1. Minispool
    By damankerrison09 in forum General
    Last Post: 27-07-2009, 03:07 AM
  2. MiniSpool
    By VryNeat in forum General
    Last Post: 29-11-2008, 01:09 PM
  3. FS: Minispool VN-VS
    By savage1987 in forum Parts And Other Items For Sale
    Last Post: 16-06-2008, 03:57 PM
  4. lsd or minispool
    By bigg_vin in forum Swap / Wanted to Buy / Trade
    Last Post: 20-04-2006, 08:08 PM
  5. window tinting whos good at it and whos not
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-10-2005, 10:42 AM
