Results 1 to 13 of 13
Thread: VN V8 break conversion.
    VN_chris is offline Banned
    VN Commodore S
    Jul 2009
    Wollongong
    Default VN V8 break conversion.
    what's the difference between VN V6 and V8 breaks? what do i have to do to change the breaks on my VN V6 to V8 breaks?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    You need:
    V8 Capilers
    V8 Rotors
    V8 Pads
    And you should be set to go
    While you're in there, you may aswell change your wheel bearings, and flush your brake fluid.
    The 1972 HQ Kingswood
    VN Commodore S
    Jul 2009
    Wollongong
    ahk cool, so all i have to do it rip the break calipers and rotors out of an ss and im good to go, how much u rekon it will cost?
    Morton's Avatar
    May 2006
    Take the calipers off of either a V8, or a SERIES II VP V6 - they had V8 brakes on them standard.
    I would also recommend buying brand new rotors and pads - while you've got the bearings out, you may aswell. Also saves the hastle of getting your second hand rotors machined.
    I suggest you should look at worst case: $80 for the calipers, $80-100 per rotor, and $60 for the pads.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Didn't we cover this like 3 days ago???
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VP Executive R-spec
    Jan 2005
    Yes we did lol, there's another thread just all about it. Morton forgot the two (BY FAR) most important things, the V8 booster and the V8 master. Which if you wanted to save money would be the first two things to change and see if you are happy with that
    car
    Jul 2006
    greensy, melb
    Quote Originally Posted by Morton View Post
    lol good on ya morton, thats how ya spell brakes, unless you want your brakes to break?
    "A life lived in fear is a life half lived"
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The M/C has different thread/line mounts to the V6. Ther end of the lines wont do up nice. I needed to get the ends of the lines changed to make it fit.
    and 3 Dangerous non ABS VN's
    VP Executive R-spec
    Jan 2005
    Mine swaped straight over. Got a 1 inch master from a VP, went straight onto my VN V6, but that's worth looking out for if yours never went on
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by greenfoam View Post
    The taper was different gfor the 88 wagon and the mechanic did them so tight that they did not undo
    88GreenVN's Avatar
    Jun 2006
    So when doing the VT upgrade I had to make new lines - cos the original unit was knackered
    VP Executive R-spec
    Jan 2005
    88GreenVN's Avatar
    Jun 2006
    Pretty sure the VT unit needs different ones anyway so that was ok
    Yep purchased the addapters - but they would not fit cos the ends of the lines were all mashed up.
    I went from 15/16 to 1" and the lines were stuffed making it fit. (88 wagon) So when the VT M/C went in the lines had to be fixed
  1. how do i break in help!!!
    By kerrylee_90 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-09-2009, 03:57 PM
  2. Break ups...
    By MikesVT in forum The Pub
    Last Post: 02-03-2007, 09:56 PM
  3. They tried to break in
    By filthyphil in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2006, 09:41 AM
  4. Break In!!
    By VLACS in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-10-2005, 09:05 PM
  5. break pads? price? vt break conversion?
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-09-2005, 06:02 PM
