Results 1 to 14 of 14
Thread: VT brakes
    '90 S1 VN 3.8L A4 Wagon
    Feb 2009
    Question VT brakes
    what is required for a VT brake upgrade for a s1 VN V6?
    currently have an 1" 1/8th master brake cylinder, would that be enough?
    since i have found a set for discs and calipers for bother front and rear, just want to make sure costs don't blow out on anything else that could be required.
    thanks.
    You're probably wondering where you are. I'll tell you where you might be. You might be in the room that you die in. This is your wake up call.
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Feb 2009
    it wont answer my question on master brake cylinder size.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    1 1/8" or 1" master? 1" is all you need. What else do you have and how much is your budget? The VE spec upgrade is very good, it comes with 289mm or 322mm slotted and dimpled rotors, hub adaptors, new calipers, new pads, braided lines and brake fluid. $750 for the VE kit.
    Visit my Facebook page
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    Quote Originally Posted by Peter89 View Post
    pretty sure it will if you use the right keywords
    The Black Beauty
    Feb 2009
    Quote Originally Posted by Not_An_Abba_Fan View Post
    any other cheaper kit? cuz at the moment all the parts are starting to add up more then expected.
    VP Executive S1
    Oct 2009
    Traralgon, Gippsland, Victoria.
    hey man, those ve upgrade kits sound awsome! where abouts can you puchace the kits from??
    D-Man's Avatar
    D-Man is offline All over it...
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    check in here for something,
    greg is your best bet on this site - great prices and very fast sending. highly reccomended. he'll also let you know what's best in terms of size rotors what will and wont fit etc.
    Quote Originally Posted by lilranko View Post
    he also does the VE brake packs
    GSL RallySport - Just Commodores
    Quote Originally Posted by danja View Post
    PS. All girls are the devil. It's science.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I do the kits as well.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    That VE kit will work with a factory V8 1" master cylinder? Any advantages over the VT kit? PM me if you like, I might become very interested if I can pull some cash from somewhere.
    edit: forgot my main question - what's the minimum wheel size for these kits?
    WTB: mulberry VN interior parts
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The VE kit will work with the stock 15/16" M/cyl. The VE calipers have smaller pistons so there is less fluid displacement compared to the VT. The rotor is larger so they are more efficient.
    Minimum wheel size is 15" for 289mm rotors, or 17" for the 322mm rotor. But then 16" factory VZ rims have gone over 322's.
    The major advantage I suppose is that there is no need to upgrade any other component of the brake system. These kits bolt straight up and feel better than the factory brakes and work a shit load better too.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I like the sound of that. Not having to change from my 15x7 stockies, and keeping my original master cyl etc.. just to clarify, what's the price on a 289mm setup? is it just fronts that are supplied?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yep, just the fronts, a 289mm for a VN, which also includes the hubs would be $720.
  1. VZ HSV brakes
    By GROWLZ in forum General Discussion
    Last Post: 17-11-2009, 04:32 PM
  2. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  3. new brakes???
    By silver_bullet in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2006, 05:57 PM
  4. brakes
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-09-2006, 01:03 AM
  5. big brakes
    By roger05 in forum Projects
    Last Post: 31-01-2006, 09:15 PM
