hey ppll i have a vn calais witch is starting to play upthink the diffs just bout fxxkd???? drive on smooth road vibrations in back end , gets worse when u go slower an also when ya just rolling it knock knock knocks its not that loud ..but need to do sumthin bout it hahaha ???? whats the best way to go bout it (ie check parts oil etc) any help will be apprecated
Have you checked your uni joints?
Illegitimi Non Carborundum
Get under the car and have a play with the tail shaft. Can you move it much?
How is the centre bearing? - is there grease makes around the bearing up onto the floor of the car.
and 3 Dangerous non ABS VN's
hey cheers guys will get under it tommorow and have a look![]()
hey alll back again checkd tail shaft all solid no movement in it !!! would it be easier in park or neutral to check for movement![]()
you sure you don't just have flatspots? i got flatspots on my front tyres, switched them over to the rear and it does EXACTLY what you've just described![]()
wheels in air and in neutral and hand brake off to check for play in tail shaft
VN Calais With All The Factory Fruit I Need!
