Results 1 to 3 of 3
Thread: Coolant.. wheres is leaking from?
    VN Lukey's Avatar
    VN Lukey is offline BT1, the way to go
    Holden VN S1
    May 2009
    Talking Coolant.. wheres is leaking from?
    hey guys..
    got a problem with a mates VN S1 V6.. it has been over heating like Nuts!.. needle all the way up in the red zone in about 5min.. we had changed the thermostat and the housing then topped it up with coolant, then we started to hear a splashing noise coming from under the car.. i had a look under the car and saw a big puddle of coolant leaking from somewhere in the engine.. i saw it was leaking from the just under the right hand extractor ( air intake pipe side ) its really pissing out..a full on stream of coolant.. like someone is pouring a jug of water... its pretty bad. i felt around and it seems like its leaking from a plug thing the size of a 20c piece..and when i push this thing in it stops leaking??????
    I'm soooooooo confused what it is..lol
    i need all the help i can get...
    cheers guys..
    VT II S pack
    May 2009
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    definately sounds like a welch plug. if you stick your head under there (if you can) u will see there is a hole. there's threads on here somewhere if you search on how to change em. its not too hard to do.
    George
  1. VS leaking coolant...
    By leelee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2009, 05:03 PM
  2. Wheres my coolant gone?
    By burnsy150 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2008, 09:40 PM
  3. leaking coolant
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2008, 10:11 PM
  4. Leaking Coolant
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2006, 08:49 PM
  5. Wheres my coolant going?
    By B3NKobe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2006, 12:52 PM
