Results 1 to 9 of 9
Thread: VN running S##T!! please help
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Unhappy VN running S##T!! please help
    Hi..
    Only new here so please forgive me if i sound stupid!!
    My VN is idileing like shit! I have changed spark plugs and leads and also put a pod filter on but it idles like crap.. Also whenever the gearbox warms up it wont go into overdrive.? it makes a wierd rumbling sound and wont engage over drive!!!? PLEASE HELP!!
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    the box sounds like it is about stuffed as for the idle try cleaning out the throttle body with some throttle body cleaner made mine idle pretty damn smooth
    VN Calais With All The Factory Fruit I Need!
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    I was looking at using a carby cleaner myself, but am a little unsure as to the correct procedure. Any tips? Also i know this may sound silly 89vn, but are you sure you connected all of the spark plug leads properly? I believe a bad connection can make the engine run roughly.
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    definitly remove the TB and clean it. carb cleaner works well for this. just make sure you don't get it into the TPS (sensor on the end of the TB shaft). best to remove the IAC motor from the TB and clean all that out also.
    VN's aren't the smoothest idling engines to begin with.
    if you have a POD filter. make a shield for it to block of the hot air in the engine bay. if you don't want to then better of fitting the standard airbox and CAI. don't use the holden super6 CAI it's crap in my opinion.
    other things to look at. service the engine. oil (put a oil flush through first) , oil filter, fuel filter. run some injector cleaner in a tank of gas.
    rough running can be caused by muliple issues so you need to narrow it down a bit
    Body by Holden, Soul by Brock
    the Legend will live forever
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Hey thanks for all the help.. I hav cleaned the throttle body the other day and checked all plugs and leads but still no good? could it be the MAP sensor or something? Any suggestions would be great.. have spent $4000 on this car respraying and putting rims on but am nearly at the end of my teather!!
    VN Lukey's Avatar
    VN Lukey is offline BT1, the way to go
    Holden VN S1
    May 2009
    Quote Originally Posted by 89vn View Post
    first thing that popped into my head was ... drop in a 5litre.. LOL
    VS Exec. 3.0L VL Berlina. HJ Premier.
    Jan 2009
    Southern Adelaide
    Does it misfire or does it just idle rough? Could be injectors, could be the coil pack or a number of other things as pointed out by immortality. Maybe try a compression test.
    "Out of the hole the rotary doesn't have enough torque to pull the panties off your drunken sister"....
    VH BT1
    Apr 2006
    Auckland NZ
    if you removed the TB have a look at the vac line running from the TB to the MAP sensor. if this is hard/cracked replace it. may have a leak giving a bad signal to the MAP sensor
    Junny's Avatar
    Junny is offline purrrrrr
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    my vp was like that too i changed the spark plugs + leads and a delco tune.... its good now
    Hit the star under this post if it was any help to you =D
  1. [308] Not running like it used to
    By crazybiker in forum V8 Development and Modification
    Last Post: 12-04-2009, 03:06 PM
  2. Running in oil??
    By frenchyvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-03-2007, 08:37 PM
  3. VC running bad
    By patullose in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-01-2007, 02:09 PM
  4. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  5. Vn V6 Running
    By cohn in forum Parts And Other Items For Sale
    Last Post: 18-07-2006, 09:52 PM
