Results 1 to 8 of 8
Thread: Hmm high idle.
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    Default Hmm high idle.
    I have a high idle on my car and I received a code for my IAC Sensor, I've been told its not sitting right? I have put a 5 litre throttle body in and its been idling high since. I read somewhere on this site that some had to have a spacer on the later models? So would an IAC from a 5ltr vr engine or something fix this issue?
    VP Executive R-spec
    Jan 2005
    The IAC's are all the same, do you still have the one from your V6 throttle body?, if so stick that one in and clean the bore it goes in while you are there
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    VN SS 5.8Lt / VN Exec S2
    Sep 2005
    Central Coast, NSW
    i know this is gonna sound stupid, but have u put the sensor back properly? i know i havent put it on properly before and it idled like a bitch lol
    VS Exec. 3.0L VL Berlina. HJ Premier.
    Jan 2009
    Southern Adelaide
    Make sure that you have no air leaks.
    "Out of the hole the rotary doesn't have enough torque to pull the panties off your drunken sister"....
    VH BT1
    VP Exec
    Jun 2005
    Maybe try adjusting the base idle - a V8 will draw more air for the same engine speed than will a V6? Mark the current position so you can go back if you wish. There should be some posts about how to do it but briefly, engine @ operating temp., A/C and fan off, air duct off and block the IAC port with a finger, adjust idle to ~500-550rpm - exact speed depends on the model. It's possible that may move the TPS voltage out of range and set a code.
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    I have adjusted it, and the mechanic has put a new one on and it still idles all arse-about. Apparently there is a diffencent type of IAC in later models or something I've been told?
    VP Exec
    Jun 2005
    Sounds reasonable. There are a couple of different shapes of the pintle (on the end of the IAC motor) used.
  1. VS V6 High Idle
    By alipete in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2008, 12:43 PM
  2. high idle
    By Got_Balls in forum V6 Development And Modification
    Last Post: 12-05-2008, 11:19 PM
  3. Very high idle
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2007, 09:26 PM
  4. vn high idle
    By dave671 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2005, 12:44 AM
  5. High Idle
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2004, 12:58 PM
