I want to change the seats for comfort and was wondering what would fit and what are the most comfortable for a VN Wagon?Please help if you can and at least tell me what will fit.
CAR ,Y U NO FIX YOURSELF
have a look at mean vn ride its gotta mad interior
shhh now PUPPET
Cheers mate will do.
How do i find it???
I have a couple of disks out in my back so i need long term comfort.What series will fit,vp,vr,vs,vt?
The Ace Ventura series anyway.
I've got a vs III statesman and the seats are soft but supportive.
The statesman seats are awsome to sit on,i will get those for the front but how can i improve the back seat?Is there a series that fits vn that is more comfy than normal?Thanks for all the help guys.
Not unless you use rear Calais or Senator seats. the Senator interior that had in my Statesman had the most comfortable rear seats I've ever sat in the front were as hard as rocks and had that stupid side bolstering was no good for trips longer than half an hour and made getting in and out difficult!!!
And good luck on finding a Senator interior.
Its for a wagon though.
even if it is a sedan seat a few mods will see it in the back of your wagon thats what meanvn done hence why i sent you that way id be recommending statesman seats from any model will be better than the stockers
shhh now PUPPET
nissan tida seats are most comfortable seats ive sat in and im a mech that draves 5 cars a day
Why do you need to change the rear seat aswell? Assuming you are the owner/driver of the car.
Just wanted a set i guess and so the kids are comfy as well.I just need really comfy long distance seats in case i travel and also for around town.
senator seats a sweet as. but to help u out any vn - vs front seat will bolt straight in rear need slight mod easy as and any vn-vs rears will fit. ur best going for stato or calais
If Barbie's so popular, why do you have to buy all her friends?
What kind of mods will the rears need?
well im not 100% sure but i think u need to pull off bak seems and wrap it over the bak mounting points then seal it bak up. it makes sense to me im sure meanvn will tell ya how:P
Thanks heaps and i am going to ask him now....hmmmm statesman seats.
no probsbe sure to let us know how u go too
This site and its members are the best.Thanks a heap guys i now know what i want and fingers crossed meanvn will tell me how to do it.
he will for sure
i found my vn seats a tad boring
so this is what i did
what i did first was to find a nice comfy and neat looking set of seats that i liked best (hence the caprice seats)
with fitting sedan seats in a wagon
(note if you want the head rests in the back seat you will need four plastic lugs from a rear seat ie vr s2berlina wagon rear top or the old front seats that hold the head rests in place.)
Rear Bottom SEAT fits same as wagon to sedan
1st remove the backing of the material from the old rear top seat
you will see metal bars running through the foam then across the back frame
slide that up and the foam is now removed.
THEN YOU CAN USE A STRONG GLUE TO HOLD THE MIDDLE ARM REST IN PLACE ON THE METAL FRAME
THEN PUSH THE 4 PLASTIC LUGS INTO THE METAL FRAM ON THE BACK TOP SECTION OF THE WAGON
AND ATTACH THE L & R SECTION TO THE METAL FRAME ITS BEST TO WRAP THE MATERIAL FROM THE NEW SEATS AROUND THE BACK LIKE THE WAGON SEATS THAT HOLDS IT INTO PLACE.
YOU WILL NOTICE THE WINGS HAVE TABS ON THEM WHICH PUSH INTO THE WALLS ON THE STATESMANS AND CAPRICE I TOOK THE LUGS OFF AND ATTACHED NEW MATERIAL ON MINE AS IT LOOKS UGLY.
You are a good man meanvn and i will follow those instructions and see how i go...now hunting for stato seats.
