Results 1 to 7 of 7
Thread: VR Speed Alert fitting to a VP
    VP Commodore Executive V6
    May 2009
    Default VR Speed Alert fitting to a VP
    I recently tried fitting a VR Speed alert to my Vp Executive and found that it beeps as soon as the car stops and does not stop flashing until it stops. Is this possibly due to the type of signal (maybe analogue) being sent to the speedo? Has anyone overcome this or used some kind of converter?
    Thanks
    VP Exec
    Jun 2005
    Interesting idea. My first question is to ask which speed signal are you using, the raw sensor signal or the processed signal out of the speedo head to the ECM? I think that the ECM signal will be more likely to match the VR signal. Both signals will be digital but of differing frequency ranges.
    VP Executive R-spec
    Jan 2005
    vp
    Sep 2008
    i wouldnt mind doin this good luck with it and let as know how u went with it
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    and another idea for me aswell :P thanks!
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    May 2009
    The first time I connected into the wiring loom just under the speedo and the second attempt I connected into the wire under the stereo both with the same result. Is it possible that there is a converter just before the speedo that I am missing, I guess my next test is to take the dash out and touch the speed control to the speedo input
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    umm why bother do the level 3 dash conversion then you get one plus have a level 3 dash
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  1. speed alert
    By nickwontlose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-03-2009, 10:35 PM
  2. speed alert
    By vs_commodore_s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2008, 12:45 AM
  3. Speed alert fitting
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2008, 06:07 PM
  4. speed alert
    Last Post: 05-03-2007, 06:22 PM
  5. digital speed read out in VS with speed alert
    By vs0001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 06:09 AM
Tags for this Thread
